help blown engine
Old Jul 21, 2010 | 02:18 AM
broken98c5's Avatar
Exclamation help blown engine
well im new to this form, i have a 98 a6 with a 2.8 30v i bent all the valves in the passanger head. i have been looking for a new motor but i am finding cheaper 2.8's for vw's. my question what engines are pretty much a drop in job will a engine from a a4 or a pasaat drop in with out tomany issues or should i get one form an a6? thanks for the help.
Old Jul 21, 2010 | 03:24 AM
Kacz07's Avatar
I'm going to guess they can be easily modified to fit, but they might have different manifolds or intake tracts or something. That is my best guess and worst case scenario.
Old Jul 21, 2010 | 01:42 PM
jhuffman's Avatar
Have you considered just finding a 2.8 head? Unless you jacked all of the pistons just replacing the head should suffice
Old Jul 21, 2010 | 05:37 PM
broken98c5's Avatar
well its not really that feasiable to jus put a head on it i cant even get a head for less then a motor i can get a motor for 750 with 120xxx on it and a 90 day warrenty, if im going to spend that i want to know it will work with no issues, it is out of an a4 and all cylinders have 150psi which seems a little low but im not sure if the a4 should have a lower compression then the a6 i apperiate all the responses.
Old Jul 21, 2010 | 07:16 PM
jhuffman's Avatar
the fact that you get a motor for that astonishes me. Although you should be able to get a used head of a junker and have it cleaned and checked out for less that half of that.
Old Jul 23, 2010 | 01:29 PM
broken98c5's Avatar
i cant seem to find any one with a head. and why noy just put a new motor in it because it overheated when i discovered that the vavles where bad and i just tried to start it and all the power was on but the starter will not engage? does onyone know about that?
Old Jul 23, 2010 | 09:06 PM
jhuffman's Avatar
if the block overheated it could have warped and seized once it cooled. If thats the case your only hope is a new engine. Test the starter by taking it off, if it works off the car and not hooked up it probably means that it can't move the pistons because they are seized.
Old Jul 24, 2010 | 09:20 PM
broken98c5's Avatar
Well I don't think its seazed, it started and ran for a few seconds then shut off after that it would not crank again, I was talking to a guy a while back and he said that he had the same problem with his and that it was a wire in the stearing collium or some thing like that could anyone confirm this?
Old Jul 27, 2010 | 12:49 PM
NH_USA's Avatar
There a a zillion things that could be wrong from bad wiring, failed components, to a siezed motor.
Your questions suggest that you don't know a lot about cars - If that is the case it would be better for you to start looking for a new vehicle instead of doing a motor or head swap.
Old Jul 27, 2010 | 05:47 PM
Theiceman's Avatar
If you think 750 dollars is a lot of money when dealing with Audis you shoud DEFINITELY heed the above advice 750.00 is a drop in the preverbial bucket my friend,,
