help blown engine
Old Jul 28, 2010 | 08:37 PM
mystrodo's Avatar
Originally Posted by Theiceman
If you think 750 dollars is a lot of money when dealing with Audis you shoud DEFINITELY heed the above advice 750.00 is a drop in the preverbial bucket my friend,,
It's always cheaper to maintain these wonderful cars with the best *correct parts.. then they run forever especially each newer series engine. Take it to a real Audi indie engine shop and maybe you can get by with just a reworking the head/valves. Somethin smells funny about the price on that complete engine at that price..was it stolen
Old Jul 29, 2010 | 03:33 AM
broken98c5's Avatar
Originally Posted by NH_USA
There a a zillion things that could be wrong from bad wiring, failed components, to a siezed motor.
Your questions suggest that you don't know a lot about cars - If that is the case it would be better for you to start looking for a new vehicle instead of doing a motor or head swap.
i know plenty about cars, fords mainly and chevys, i have learned over the past year that these cars are very complex and i figured if someone has had a similer issues or experiances. that it is always better to doubble check what i have assumed or know (on a side note, i have been working on cars for 10 years i have been an ASE master mechanic for 2 of those years) thanks for your help!
oh, they are amazing cars i got it cheap thinking it would be an easy fix but.........apparently not, i think one of the cam adjuster units gave out. anyway it is a tested motor from a reputable co. it has a 90 day warrenty if it dosent run they will replace it
Old Jul 29, 2010 | 08:10 AM
oldmots's Avatar
In this situation, I would recommend having the engine looked at to see if a new/used head is the best solution. Generally, if everything else seems okay (such as the tranny), this would be the cheapest route.You might need to find a friendly shop to help with this. A knowledgeable independent shop should be able to take care of this for around $1500-2000. If you are a good mechanic, you could do it for half of that or a little less (general rule of thumb, car repairs are half parts, half labor). You could weigh the value of the car once it is repaired, cost of replacement of the car and complete engine replacement in your decision.
QUIGGS2001
Jan 20, 2013 07:36 AM
bkurowski011
Nov 19, 2011 05:12 PM
dab_master
Oct 5, 2007 08:37 AM
ugcpower.com
Jun 15, 2006 10:34 PM
ugcpower.com
Jun 15, 2006 08:02 PM
