Help... Huge Repair Bills
Old Jun 10, 2008 | 10:25 AM
katcoota's Avatar
Default Help... Huge Repair Bills
Help...
I dropped my car off this week to get a few problems fixed. I've already replaced the water pump, t-stat (not done when the previous owner did the TB... I know I know). Front and rear pads. A gearbox gasket and seal.
Well,2 days later[:@] and the list has grown and now I need:
Anew radiator
New steering rack
New tie rod ends
Does anyone know if the steering rack is different between the A6 4.2 and S6? Here is one I found that didn't seem to bad price wise, but no idea if it is what I need
http://www.carsteering.com/addtocart.../80-00768.html
or here:
http://www.powersteeringpros.com/par..._Rack/80-0.asp
Thanks guys
Old Jun 10, 2008 | 11:14 AM
hxgaser's Avatar
Default RE: Help... Huge Repair Bills
Rack itself should be the same. Earlier serial numbers had different tie rod ends I think.
Old Jun 11, 2008 | 01:57 AM
katcoota's Avatar
Great, that is a bit of a relief. Online I can get them for around a third of the price of a dealer's remanufactured one.
Is there any difference between the steering racks on a wide body A6 and the narrow bodied ones?
Old Jun 12, 2008 | 12:01 AM
differcult's Avatar
Why do you need a new steering rack. I was told that I had a bad rack...turned out to be a bad mechanic .... Problem was fixed with a tie rod.
Old Jun 12, 2008 | 02:12 AM
katcoota's Avatar
My steering rack is leaking. I got it checked by at least 2 independent mechanics. The steering is also getting heavy turning left compared to turning right.
I've also got an additional CV boot that needs to be replaced.
Old Jun 12, 2008 | 10:02 AM
wammy18's Avatar
What did you do?? Jesus :P
Old Jun 12, 2008 | 02:26 PM
katcoota's Avatar
Actually, these have been pending issues for a long time. Since I got the car a year ago, things have been slowly leaking. I made sure I was on top of things, such as with the coolant and steering fluid.
I finally got round to replacing the water pump, and had the radiator repaired for now. As it was a small leak x 3, it didn't cause any 'serious' problems. If the level of coolant still goes down, then I will have to replace the radiator.
The steering rack was mis-diagnosed originally as the Power Steering pump. That will have to be replaced.
Old Jun 12, 2008 | 04:07 PM
hxgaser's Avatar
Try the following website.
http://www.trademotion.com/partlocator/index.cfm?siteid=215021
It is helpful when you are comparing parts. Based on the information, A6 and S6 rack is the same.
Old Jun 14, 2008 | 03:59 AM
katcoota's Avatar
Thanks for that link. Yikes it is pricy.
Old Jun 18, 2008 | 11:29 PM
gmatov's Avatar
Kat,
What kind of prices are you getting for a rad? Mine sprung a BAD leak a couple weeks ago, called my mechanic, told him I had a prob, told me he would call for a rad the next AM. Drove up, he told me he called, wouldn't order, price was 750, I'm tight.
Called my local foreign car wrecker/repair/parts place, told him I wanted a rad, he started with used, said no, new, he got me a new one for 118 bucks, delivered the next afternoon, installed the next day.
I don't do my own work anymore. Seems to me the rad was lighter than the ones I have changed in older models I have changed out myself, but that could be because they still had coolant in them, or my own memory is failing.
I don't know where you are, I don't know if they would take a long distance order, but if you want to try them, I know my e-mail is posted, I could direct you to them.
Cheers,
George
