HELP ignition
Old Aug 31, 2009 | 12:02 PM
kuka's Avatar
Default HELP ignition
1996 A6 2.8L Quattro. My key does not kick-back from the on pission, so the starter does not disengage. Can this be fixed without a whole new key cylinder and set? or maybe a push-button start?
Old Aug 31, 2009 | 09:11 PM
chefro's Avatar
You'll have to replace the ignition switch....cheap part, hell of a PITA to do. Buy yourself a pair of small hands with the switch and a bucket of patience.
Old Sep 1, 2009 | 10:03 AM
NH_USA's Avatar
consider yourself lucky.. When mine failed it would not turn off.
the switch mechanism is on the back of the tumbler set. As chefro said small hands and patience -- sometimes it is easier to remove the whole switch mechanism,. but it depends upon how much fun you want to have..
Old Sep 2, 2009 | 08:00 AM
aliyork35's Avatar
ignition switch is needed to be replaced. there might be wiring problem
DraxeofDclan
Feb 28, 2009 09:24 PM
jdes
Aug 17, 2007 09:49 PM
techguru
Jun 18, 2007 10:17 AM
sid0013
Jan 23, 2005 07:25 PM
