High current draw when ignition is off, drains battery.
Car:
02/03 Audi A6 Avant (4B, C5) 1.8 T quattro manual trans.
Problem:
Battery goes flat over night.
Findings:
This list of fault codes looks frightening, but the information panel between the odometer and speedometer says OK. So to the unknowingly, everything seems OK.
Problem:
Findings:
- Battery voltage at rest, charged: 12.6V
- Alternator Charging voltage: 14.2V
- Current draw (measured via negative battery cable to negative battery terminal) when ignition is off: More than 2A.
- Excess current draw ceases when fuses 15 (Kombigerat, Klimaanlage) and 37 (Telefon, Radio) are pulled.
- When ONLY fuse 15 is pulled, the current increases is a pulsing manner, almost like when engaging the turn signal.I don't know if this is normal behaviour.
Code:
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Sunday,05,May,2013,10:00:22:39271
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WAUZZZ4B83N004654 Mileage: 116150km/72172miles
Address 01: Engine Labels: 06B-906-018-AWT.lbl
Part No: 4B0 906 018 DC
Component: 1.8L R4/5VT G 0001
Coding: 11702
Shop #: WSC 02325
VCID: 65C16926FFF8A130B2A
WAUZZZ4B83N004654 AUZ7Z0B2163064
1 Fault Found:
18010 - Power Supply Terminal 30
P1602 - 35-00 - Voltage too Low
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 1728
Coding: 06275
Shop #: WSC 00000
VCID: 26432E2AC27E6A287B0
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00000
Shop #: WSC 02325
VCID: 5CB74CC2CCB2E0F81D4
3 Faults Found:
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 P
Component: Airbag 8.4EP 2002
Coding: 0000706
Shop #: WSC 02325 785 00200
VCID: 3D71E14667E8C9F00AA
3 Faults Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
00592 - Seat Belt Switch; Passenger (E25)
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 933 N
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 00144
Shop #: WSC 00490
VCID: 2E53D60AEA8E2268830
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
01304 - Radio
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 L
Component: Zentralverriegelung D37
Coding: 06721
Shop #: WSC 02325
VCID: 326BC27AFEB60688E78
5 Faults Found:
07-10 - Signal too Low - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
59-10 - Can't Unlock - Intermittent
01560 - Passenger Door
60-00 - Won't Safe
61-10 - Won't De-Safe - Intermittent
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4B0 035 192 K
Component: RNS 4.2 H06 BNO 0102
VCID: 25412926BF78613072A
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00050
Shop #: WSC 02325
VCID: 040754A214827838054
1 Fault Found:
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 00490
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No: 4D0 919 146 B
Component: TV Tuner H08 0805
Coding: 0000010
VCID: 285F2012986A7C5849C
End ---------------------------------------------------------------------
Follow-up post:
I ended up purchasing a new battery, which I installed 13th of May 2013. I deleted old fault codes and started using the car as normal. After this I have not been able to reproduce the problems as described above. Problem solved, actually. I would never have believed that an old battery would cause these kind of problems, but it seems like this actually was the case. In the future I will be less reluctant to buy a new battery when the car fails with similar symptoms...
I had the same thing happen with my 1998 A6 2.8 30v. The battery was draining, tested ok. I thought it might be the hood switch, but then left it at auto parts store for a day to drain and trickle charge, it tested bad. Replaced battery, no further problems.
the same thing keeps happening to my battery it drains over night when the radio fuse is in. I got the battery tested yesterday and they said the battery was good but this morning I went to crank the car to go to work and the car would not start
intergalactic
Mar 5, 2012 09:42 AM
compman723
Jun 13, 2011 09:59 PM
salinas
Dec 11, 2007 08:09 PM
