How to check my timing?
Old Feb 6, 2007 | 07:36 PM
toto's Avatar
Default How to check my timing?
When I start TDIGraph and choice AFB (my engine type) VAG-COM shows me this graphic:
In my VAG-COM I had not AFB engine in the drop down, but I found this TDIGraph.cfg file from Ross-Tech site->TDIGraph->Version History:
http://www.ross-tech.com/vag-scope/tdigraph.cfg
Now I don't know what to do. Should my Timing value to be negative?
Old Feb 6, 2007 | 09:10 PM
2k S4's Avatar
Default RE: How to check my timing?
TDI does not work on Audi's.
If you want real time data use
http://www.ross-tech.com/vag-scope/index.html
Other then that, you have to use "measuring blocks" under 01 engine, then 04 basic settings, then pick 03
Old Feb 7, 2007 | 01:13 AM
toto's Avatar
Thank you for the info. But what values I should to look in 004 Basic Settings and what are the normal values?
Old Feb 7, 2007 | 02:28 PM
2k S4's Avatar
ORIGINAL: toto
How about ignition timing?
Normal? What's normal? It will change with, engine temp, oil temp, air temp, throttle input, gas quality, throttle input, engine load ......
What are you trying to find out? I would not get hung up on the values. If you want to see if there are any problems, log the knock sensors.
You need to got to http://www.ross-tech.com/vag-com/tour/main_screen.html & learn how to use Vag-com.
Old Feb 7, 2007 | 05:01 PM
toto's Avatar
If this can help here I made screenshots of many values:
http://www.toshko-bg.com/snimki/audi/vag-com/
I have problem with the cold start.The engine starts slow with round 6-10 seconds cranking. I went to mechanic and we set ATDC in basic settings Group 004 to 2,2 butit not help. I have read on many forums in internet, that I should set the timing. I know that I should rotate a little bit the fuel pump, but I don't know where to check for some values that I should adjust. So if someone can help me with info how to set the timing I will be very pleasure. Everywhere the people are saying that I should use TDIGraph in VAG-COM, but also the people are saying that itwant notwork for my car.
And sorry for my bad english. I'm bulgarian [sm=headbang.gif]
Old Feb 7, 2007 | 05:06 PM
techbod's Avatar
screwing with the dieselfuel pump is your first mistake ( set it to the manufacturers specs ) then change the glow plugs which in most cases is the cause for hard starting
Old Feb 7, 2007 | 05:44 PM
toto's Avatar
The problem is not in the glow plugs. When my car is into the garage it is not so cold and glow plugs are off. Sometimes when is more cold or the car is for the night out of the garage the glow plugs starts for few seconds and then the starts is better, but still is not ideal.
When theengine is too hot (e.g. after driving on highway) also the start is hard.
Old Feb 7, 2007 | 05:56 PM
techbod's Avatar
then it could be pump timing is out or injectors are bad, im going for diesel pump timing because you messed with it and you need the tools to set up the engine timing to the pump timing other wise its not possible
Old Feb 7, 2007 | 07:42 PM
toto's Avatar
Sorry I can't understand you.
Do you tell me my pump is broken or I need to set someting?
Old Feb 9, 2007 | 01:50 AM
toto's Avatar
Hello again,
I made a log of the moment of the cranking. If this can help youto get me some info about my hard start:
http://www.toshko-bg.com/snimki/audi...m/vag-com.html
FantasiA4
Nov 15, 2013 07:01 PM
rkelsey10554
Oct 19, 2013 10:43 AM
Expplucky
May 29, 2013 07:37 PM
Spoke
Sep 24, 2008 11:37 PM
Silver98A4
Oct 14, 2005 12:00 PM
