How to check for Vacuum leaks
Old Jul 29, 2008 | 10:57 PM
michaelh305's Avatar
Default How to check for Vacuum leaks
How do you check for vacuum leaks? I am showing the codes for running lean on bank 1 and 2. does that mean it is the mafs? I am also showing the code for Leak Detection Pump Failure. Any suggestions? Oh yeah I have a 2000 A6 Quattro 2.7T. Thanks!
Old Jul 30, 2008 | 11:26 AM
hxgaser's Avatar
Default RE: How to check for Vacuum leaks
Clean MAF and check this post.
https://www.audiforums.com/m_934274/tm.htm
Old Jul 30, 2008 | 07:21 PM
Alright I cleaned the MAF with MAF Sensor cleaner. . .nothing. Dissconnected it drove down the interstate everthing was fine, reconnected and same hesitation and power lost when reaching full boost. Does that mean the MAF is bad? and any idea about the Leak Detection Pump
Old Jul 30, 2008 | 07:47 PM
hxgaser's Avatar
Probably MAF is bad, As for the leak detection pump, what are the actual codes?
Old Jul 30, 2008 | 08:51 PM
that code is P1476 can that be tied into the MAF being bad? Definition is EVAP LDP Malfuncion/Insufficient Vacuum. Thanks
Old Jul 30, 2008 | 09:41 PM
hxgaser's Avatar
Did you by any chance get a flat tire recently?
Old Jul 30, 2008 | 09:53 PM
hxgaser's Avatar
Well, anyways, check the following website.
http://www.jambolnet.com/stoian/Audi...20checking.pdf
Also check the N80 valve too. You should hear that thing clicking away.
Old Jul 30, 2008 | 10:20 PM
Now should the Leak Detection Valve be making noise or should I be able to put my hand on it and feel it working? Hey thanks for the help
Old Jul 30, 2008 | 10:21 PM
Old Jul 30, 2008 | 10:45 PM
hxgaser's Avatar
You should hear it pumping, but not always, because it only turns on and off depending on the pressure. The reason that I ask about the flat tire is that I read in many instances if you get a flat on right front, it can damage one of the EVAP lines from N80 valve. N80 valve always clicks away.
The other issue can be the gas cap. If you checked all the vacuum lines and EVAP related hoses running to N80 valve and EVAP LDP, then next least expansive option is to check the gas cap. Othewise, you are probably talking new pump.
