how to reset service OIL indicator
Old Dec 13, 2011 | 01:21 PM
Tourbo24's Avatar
Default how to reset service OIL indicator
I have looked around and the methods that I have found so far are not working for me. What is the proper way of resetting the service oil/inspection indicator on an audi a6 c5 2.8q.
Old Dec 13, 2011 | 02:01 PM
02A6Beau's Avatar
vag-com
Old Dec 13, 2011 | 06:27 PM
nm3210's Avatar
Old Dec 13, 2011 | 07:04 PM
Tourbo24's Avatar
thanks for the link, but when you scroll all the way down you can see that i posted on there too because it wasnt working for me ;/
Old Dec 13, 2011 | 10:11 PM
budhani786's Avatar
you have to turn off the car. press the button which "zeros" the miles put the car's in on position but not starting it and pressing the other dial by the "0" one. if that doesnt work you will have to use a vag-com
Old Dec 14, 2011 | 12:01 AM
Tourbo24's Avatar
so when i press the right hand side button, do i hold it in and turn the ignition on while still holding it in. then when the ignition is on, do i still hold that one and press the one on the left too, or do i let it go and then press the the one on the left? lol this sounds so confusing.
Old Dec 14, 2011 | 04:38 PM
hxgaser's Avatar
Press and hold in the right button while turning on the ignition. If I remember correctly, then it will blink or something like that. Release the button and press and hold it until the mileage is reset.
Old Dec 14, 2011 | 04:40 PM
hxgaser's Avatar
One more thing to add... It will only reset if your service remaining mileage is 1000 or so miles and it is coming on when you turn the ignition on. i.e. 2500 mile showing on the reminder will not allow you to reset.
Old Dec 14, 2011 | 04:56 PM
Tourbo24's Avatar
just found my manual which was under the steering wheel in a little pocket
after following the instructions in the manual i managed to reset the inspection and oil indicators ) im a happy camper now lol
Old Dec 15, 2011 | 07:37 AM
Lazydog's Avatar
Last Place - just "necause"
So post what worked for you so the next person searching and finds this thread will have the answer.
