i have a 2001 audi a6 4.2l big problem somone helppppppp
Old Feb 27, 2007 | 01:18 AM
xxemranxx's Avatar
Default i have a 2001 audi a6 4.2l big problem somone helppppppp
well my timing belt broke whats the chance the valves are bent anyone knoe if the audi isinterferenc motor i think i forgot whats its called but a system that stops the valves from hittin the pistons or somthing
Old Feb 27, 2007 | 01:23 AM
SouthboroAudiGuy's Avatar
Default RE: i have a 2001 audi a6 4.2l big problem somone helppppppp
Bad news mate. The 4.2 is an interference engine. You've probably got a pretty big bill on your hands. For your sake, I hope a miracle happened and you didn't fry your heads/valves.
Old Feb 27, 2007 | 01:31 AM
xxemranxx's Avatar
but i thought if its an interferen motor the valves wont hit the pistons or anything idk
Old Feb 27, 2007 | 01:55 AM
Interference motor means that the valves WILL hit the pistons should the timing belt break.
Old Feb 27, 2007 | 01:57 AM
modset's Avatar
the valves can bend on an interference motor, hence the word interference.
Old Feb 27, 2007 | 02:42 AM
auditech79's Avatar
Yep, i just did a set of heads on a 4.2L that broke its timing belt too. The total cost of the repair was
$5000 installed with a new water pump timing belt and rollers. Sorry bro.
Old Feb 27, 2007 | 01:10 PM
prbayha's Avatar
Well..how fast was the engine turning when it broke (RPM)? If it was at idle and you shut it off right away, you might get lucky. Man, that sucks big time.
Old Feb 28, 2007 | 02:46 AM
xxemranxx's Avatar
well i was involved in an accident like 30 miles and hour and hit in the front and like the core support came bak smashed the timing belt cover i think and the timing belt snapped als i have a crack in my intake manifold
Old Feb 28, 2007 | 03:17 AM
auditech79's Avatar
Well if you got nailed audi's have a saftey cut off when an accident happens which means the computer might have shut off the engine before the timing belt snapped which is good news for you.
Old Feb 28, 2007 | 11:54 PM
xxemranxx's Avatar
how sure are u about that
