I need someones help
Old May 6, 2009 | 09:53 PM
crazass's Avatar
Default I need someones help
I just replaced my brake light (the one in the rear window) with an led strip.
One thing I forgot to measure was the ohms on my old light (due to modification of ). Can someone measure it for me?
Cause my indicator came on now .
Thanks in advance I will post pics of it soon. It looks good so far
Old May 6, 2009 | 11:51 PM
auditech79's Avatar
What do you mean can someone measure it for you? Do you want someone to measure the OHMs in their personal car?
Old May 7, 2009 | 06:20 AM
crazass's Avatar
Default sorry
I maybe I wasn't clear on it.
I would like for someone to remove the rear top brake light (very easy to remove from inside trunk) and calculate the resistance of the light.
To see how much current is passing. So I can measure mne and see the difference. Because my dash light came on warning me about a burnt bulb
Thanks
Old May 7, 2009 | 12:14 PM
jason23silver1's Avatar
The only way to solve your problem is to install a resistor on the actual wire that connects the brake light. You will have to solder it. I had to do this while changing certain bulbs on my car to Led's.
Old May 7, 2009 | 05:26 PM
crazass's Avatar
Default size of resistor
Do you know the size of resistor it is ?
a4nick
Jan 21, 2011 10:50 PM
drev500@aol.com
Apr 4, 2008 07:13 AM
