I need your guys' help on brake maintenance
Old Aug 20, 2008 | 05:55 PM
zwhid's Avatar
Default I need your guys' help on brake maintenance
So a few weeks ago the warning lights for my brake pads came on. I finally got around to taking it into the shop yesterday. Today they called me and said that it would be 600 dollars for rotors and pads! I was a bit surprised at this because my sister's SUV came to around only 300 dollars at the same garage. Am I being taken for a fool by this mechanic or does 600 dollars seem reasonable?
Old Aug 20, 2008 | 06:09 PM
oc_audica's Avatar
sounds about right for everything depending on his shop rate
check out how much the parts would be on purems.com
IIRC parts would be about $350-400
Old Aug 20, 2008 | 06:32 PM
zwhid's Avatar
hey thanks for the help! thats a really good website. i should also add he needs to replace the cv boot and he says that will be another 300 dollars bringing my final total to 900 =(
Old Oct 19, 2008 | 10:51 AM
01A6Turbo's Avatar
zwhid, that's about right. I purchased just REAR rotors and pads from the dealership and their prices were - $70/rotor (x2 = $140); $55 for a set of rear pads (L & R). Front pads & rotors are even more expensive than the rear. So right there is probably your $300+ just for parts. THen consider his hourly rate. Good luck man! Consider changing them yourself?
Old Oct 20, 2008 | 11:30 AM
bob martin's Avatar
Is the price quoted for all four? If so - reasonable. If one axle only - too much.
Bob
Old Oct 20, 2008 | 05:29 PM
CosminTX's Avatar
i paid around 130 for pads all 4 wheels, and another 100 for rear rotors only , plus another 30-40 for tools that i still have(stands, front and rear caliper tools, grease, dot4), and i did it myself, easy job. if i had different wheels i probably paint the calipers red, but that`s a different story.
another thing if your pads are gone , u must replace them if not, u end up like me , the pads destroy the rotors in the rear because i delay everytime plus the rear pads doesn`t have sensor on my a6 model
Old Oct 20, 2008 | 07:41 PM
Kevin's Avatar
Take the $600 and use it as a down payment on Brembos.
Old Oct 21, 2008 | 12:50 PM
ppgoal's Avatar
Last July I replaced frt/rear pads with Centrix, turned the front rotors, and replaced the rear rotors. Total was $545 at my indie shop. Pads were $143 and rear rotors $50/each. Your costs seem in line.
Old Oct 21, 2008 | 01:05 PM
NH_USA's Avatar
I get good rotors for about $30 each and rebuilt loaded calipers for around $125 each. Pads for each end run $35 -40. So it depends upon what has to be replaced.
Pads only - $80
Pads front, 4 rotors, two rear calipers - $415
You do the math for your situation.
As for the boot - I always do a rebuilt half shaft - about $125 - so I get new inner and outer boots -
Old Oct 22, 2008 | 11:25 AM
robdance30's Avatar
I just did the front pads myself for $50. You need a 7mm hex that you can buy at Sears for $5. If you know what you're doing it takes about 30min.
