Issues with DEBADGING
Old May 23, 2007 | 12:37 PM
shockedimpy's Avatar
Default Issues with DEBADGING
I just got finished debadging my A6 2.7T and I bought the GooGone. I used the dental floss, and GooGone to get the plastic symbols off with ease. I then took off the HEAVEY adhesive that was remaining, but my issue is the OUTLINE of the A6 2.7T is still on it. Is it suspose to be like that, then come off on its on over time, or is there something I can do to get the OUTLINE out? Did anyone else have this issue?
Old May 23, 2007 | 12:50 PM
RIA6's Avatar
Default RE: Issues with DEBADGING
Take some rubbing compound to it, that should do the trick!
You will want to wax that area after as well!
Old May 23, 2007 | 12:52 PM
What rubbing compound would you recommend? And which wax?
Old May 23, 2007 | 02:57 PM
slee22's Avatar
Turtle-Wax Polishing Compound should work with a little elbow grease. The wax is up to you, I use Zymol.
Old May 23, 2007 | 03:12 PM
Joeski's Avatar
I wouldn't use Turtle Wax on my neice's Radio Flyer! I would recommend 3M Fine Cut Compound, Light or Dark swirl remover (depending on your cars color) and finish with a pure Caranuba. You'll be good to go!
I like 3M but there are other fine products as well, Meguires, P21S, etc. Go to www.autopia.org, it is a fantasic site for the serious detailer.
OOOO
Old May 23, 2007 | 03:48 PM
RIA6's Avatar
3M is definately the way to go...
Wax; my personal choice is Liquid Glass!
Old May 23, 2007 | 03:57 PM
Thanks guys! I ended up going to AutoZone before I got any of the replies back of what kind of compound to get. I got the Turtlewax, and with a bit of elbow grease the car looks beautiful. Thanks again guys!
Old May 23, 2007 | 04:47 PM
indyaudiguy's Avatar
So it did come out? I took mine off last week and there it is A6 right through the clear coat tothepaint.
Old May 24, 2007 | 04:31 PM
Yes it worked perfectly. I'd recommend it.
Old May 24, 2007 | 04:43 PM
Joeski's Avatar
Turtle Wax is a terrible automotive product! I wouldn't polish a beer can with it!
OOOO
