K&N filter and MAF
Old Dec 17, 2008 | 03:53 PM
biocpu's Avatar
Default K&N filter and MAF
Several threads suggest the filter may damage MAF due to the oil in the filter. But the K&N's office response states (1) such claim is flawed (2) the oil is the integral part of the K&N's technology. http://www.knfilters.com/MAF/massair.htm
Any idea whether to use the K&N?
Also do you really re-use the K&N?
Old Dec 17, 2008 | 06:47 PM
Kevin's Avatar
K&N is great if you do not want any measurable improvement in performance and you want to deal with maintenance/durability issues. Obviously my vote is to skip it.
Old Dec 18, 2008 | 11:45 AM
hxgaser's Avatar
Over oiled K&N WILL mess with your MAF. It worked great on my old Honda with MAP. I have it on my A6, but I make sure I under oil the filter everytime I clean it. FYI, if my car wasn't chipped, I probably would not use it on my car.
Old Dec 18, 2008 | 01:07 PM
the G man's Avatar
Yeah, just dont over oil it and your MAF sensor will be fine. I usually just replace my K&N every 2 years. I dont bother re-oiling them.
Old Dec 18, 2008 | 01:44 PM
DÌEGØs AÜD!CTIØN's Avatar
yup, like everybody else said just make sure its not 'over-oiled' and another thing you can do is clean ur MAF every once in a while (or everytime you change/re-oil it)
Old Dec 18, 2008 | 01:48 PM
Jeffla's Avatar
I say this every time, but do an oil analysis before and after the switch to the K&N filter. They let in a lot more dirt. I never kept mine in long enough to have to clean and re-oil. After seeing the oil analysis results I threw it away.
Old Dec 18, 2008 | 02:03 PM
whats an oil analysis??
Old Dec 18, 2008 | 04:58 PM
Jeffla's Avatar
http://www.blackstone-labs.com/what_..._analysis.html
They are a great way to detect problems with your engine. ie coolant in the oil, fuel in the oil, excess silica(dirt)..... I change my oil at 5k with synthetic because that is about when the oil begins to break down.
Old Dec 19, 2008 | 12:47 AM
^^^ interesting....
Old Dec 19, 2008 | 01:12 AM
chefro's Avatar
What AIR has to do with OIL?
The last time I recall, combustion is provided by an AIR-FUEL(GAS) mixture. Dirt in oil doesn't come from the ...air filter. Would you be kind enough to explain how an oil analysis is related to the air filter?
Thanks.
