Key Fob Synchronisation - A6 2005 2.4 SE
Old Apr 26, 2012 | 06:21 AM
jonstannard's Avatar
Default Key Fob Synchronisation - A6 2005 2.4 SE
Hi All
I was hoping someone may be able to help me with my key fob. the battery is fine, however it only works intermittently, and I suspect it may need re-synchronising.
Does anyone have a guide / tips how to do this? I'm getting fed up of using the physical key to unlock the car!!
Thanks
A6 2005 2.4 SE
Old Apr 26, 2012 | 10:10 AM
eejimm's Avatar
Working intermittently means that it is programmed correctly (or rather that the car is programmed to the fob) - if they are not, the car will never recognize it. You can try re-setting it (really simple to do, but you need 2 working keys or a VAG-COM - search the archives here for the procedure) but your issue seems more like an intermittent problem in the fob itself, or (more unlikely) in the remote receiver. Sounds like you only have one fob - this is why it's nice to have two so you can compare and troubleshoot.
Jim
Old Apr 26, 2012 | 10:12 AM
hi Jim
thanks for your comments. I have two fobs, but they seem to both have the same issues! can you direct me to the reset procedure? maybe that will help!!
cheers
Old Apr 26, 2012 | 10:56 AM
eejimm's Avatar
ajax19
Jan 7, 2011 09:32 PM
FRm_H3toAudi
Aug 16, 2008 08:00 AM
dr6837
Jan 11, 2008 07:59 PM
4Rings
Nov 1, 2005 05:22 AM
