Large Brakes 2003 A6 2.7 Q
looking a the calipers it should be obvious if they are or not. Mine barely fit in the stock 16" rims and completely encompass the rear portion of the rotor ie they couldn't possibly be any bigger and still fit
As far as I remember the sinle piston brakes were called "Ate" type;
The Multipistons - "Girling" /Lucas.
2003 A6 has Ate, 321mm rotors
Big brakes - on S8 are:
323x30 Rotors - Lucas - 4 pads per wheel
345x30 Rotors - Ate - 2 pads per wheel\
RS6 -365 X 34mm
The easiest way to figure out what is the config on your car is to call dealers with your VIN.
RS6 -365 X 34mm
http://www.blauparts.com/audi/audi_b...isc_size.shtml This is helpful in determining what rotor/pads your A6 has.
shanpai
06-28-2008 01:25 PM
