Looking for Front strut mounting bracket
Old Mar 12, 2009 | 08:54 PM
kevin1533's Avatar
Default Looking for Front strut mounting bracket
Im not sure if anyones had this problem, but after having my upper control arms installed recently, I have been hearing loose screw/nut sounds as I drove.
I tightened all parts however it persisted. It so happens I checked the bolts for the strut mounting bracket and one of the bolts were loose.
I tried to tighten the bolt but the mounting bolt bracket part seems to have been damaged as It would not tighten even with another bolt.
I figure the mechanic didnt tighten the bolt and I drove on it loose until it became damaged.
Anyone else had the same issue?
Im looking to replace the front strut mounting bracket but cant seem to find any sites online. Any suggestions?
Old Mar 13, 2009 | 12:09 AM
chefro's Avatar
Is the "bracket" you're referring to the same as a "mounting plate"?
If yes, then try Autohausaz.com.
For my 1995 one mounting plate is $ 21.
m6amba
Aug 27, 2008 09:04 PM
sfaudi2008
May 13, 2008 11:18 PM
Quattro_1.8t
Apr 3, 2008 06:03 PM
duhg
Mar 3, 2008 07:50 PM
tekkie
Oct 29, 2007 09:56 PM
