Low RPM
Old Nov 9, 2006 | 10:47 PM
MiniSpdRcr's Avatar
Default Low RPM
Ok...well I am new to the world of Audis and did do a search but really did not come up with anything. The problem is, that when I brake and come to a complete stop the RPMs drop to about 250 then raise back up. I do not know if they all do that or just mine. What could be wrong, if anything?
Old Nov 15, 2006 | 07:11 PM
MiniSpdRcr's Avatar
Default RE: Low RPM
Could this possibly be bacuse of a leaking valve cover? Maybe gets some extra air in there?
Old Nov 18, 2006 | 11:16 PM
dankhound's Avatar
Default RE: Low RPM
Check for vacuum leaks.
Old Nov 19, 2006 | 01:37 AM
MiniSpdRcr's Avatar
Default RE: Low RPM
How would I go about this? Oh so could this be the leaking valve covers then?
Old Nov 19, 2006 | 02:06 AM
twinturbomew's Avatar
Default RE: Low RPM
Try pressure testing the system. I dont belive I found out what kind of motor you have. But check for unmetered air. This will cause this to happen
Old Nov 19, 2006 | 01:02 PM
MiniSpdRcr's Avatar
Default RE: Low RPM
It is a 2.8 30v, where do I take it to pressure tes it? And how do I check for the unmetered air?
Old Nov 21, 2006 | 06:08 AM
Default RE: Low RPM
With a NA car it is harder to check for vac leaks due to the check valves. Look at your MAF and all the vac lines around the intake system.
the best way to do this is to let the car idle and feel around the motor and listen for air leaks.
Old Nov 21, 2006 | 06:36 AM
techbod's Avatar
Default RE: Low RPM
any fault codes? vacuum lines would be the first area check for aged pipes ( rocker cover gasket ?? naaa ) that would be an oil leak issue, air filter dirty/ intake - exhaust leaks
Old Nov 21, 2006 | 11:32 AM
MiniSpdRcr's Avatar
Default RE: Low RPM
Well I replaced my air filter, yet I sill have it, not as bad but its there. Seems to want to drop to 250-500 RPM. Im waiting on a person with a Vag-com to come pay me a visit. He's a busy man.
I also got a recommendation to spray brake cleaner to find the leak...
Old Nov 21, 2006 | 11:36 AM
techbod's Avatar
Default RE: Low RPM
#1 a few other things to check out
[IMG]local://upfiles/12092/B7085221088E4C96A7057ABECBEFEFA0.jpg[/IMG]
