Maf input low
Old Aug 30, 2008 | 04:07 PM
wammy18's Avatar
Default Maf input low
Today I was going around a turn and when i went to throttle I heard almost like a POP. At first I was worried it was the turbo. The ABS light came on and the ESP light is on. No code came up from the car. I connected the vagcom and got a reading of MAF input low. Do you think I simply blew my MAF sensor and need a new one? Or do you think further problems?
Old Aug 30, 2008 | 04:52 PM
jaymac's Avatar
How many miles on your car and how many miles on the mods?
Is it still you original MAF?
The ECU didn't throw any codes for the ESP or ABS? And did you lose traction, causing the ESP to come on??
Old Aug 30, 2008 | 05:08 PM
wammy18's Avatar
nope.. just low maf input. no loss of traction. new maf 8k miles ago - 10k
Old Aug 31, 2008 | 09:31 AM
jaymac's Avatar
How many miles on the car itself? Have you ever cleaned your MAF? I know they can be prone to getting dirty and/or going bad...
Old Aug 31, 2008 | 11:26 AM
wammy18's Avatar
66k miles on the car, 10k since it was put on by the dearler.. replaced about 1-2k miles ago because they thought it was faulty. Mehh i don't know if I want to clean it but I guess I could take a shot using ??
Old Aug 31, 2008 | 07:40 PM
hxgaser's Avatar
MAF cleaner... You need a security torx bit, not a regular torx!
Old Sep 1, 2008 | 01:58 AM
wammy18's Avatar
what do you mean hxgaser? sorry, and so you think it doesn't need replaced?
Old Sep 1, 2008 | 01:59 AM
wammy18's Avatar
the car also drives normal and doesn't throw a code for a little while
Old Sep 1, 2008 | 11:26 AM
Kevin's Avatar
Are you using K&N filters? They are tough on the MAF
Old Sep 1, 2008 | 03:33 PM
wammy18's Avatar
Yah I have been doing some reading and have noticed extra oil gets through with the k&N filter... My thoughts r its shot ;p
