Mil p0421, p0431
Old Oct 23, 2010 | 08:36 AM
bigdadi's Avatar
Default Mil p0421, p0431
Check engine lights on re left and right warmup Cat efficency.
If no bad CAT symptoms and passed inspection, OEM ECU threshold was set too narrow range. A little out of spec then the CEL pops out.
Audi TSB about fixing this low threshold problem on certian Audi year/model by flashing the ECU/ECM with the updated software. This will clear this MIL problems. Not all Audi dealers will do flashing ECU though.
Dealer will want over $2,800 to replace both CAT converters.
"Mini-Cat-CEL-Fix" and it works. http://www.bigdaddiesgarage.com/
Old Oct 25, 2010 | 09:55 AM
oldmots's Avatar
The test for these codes is to check the O2 sensors and control systems. The CAT is not the issue until the O2 sensor is checked. Get the sensors monitored in real time to see what the O2 sensors are doing. I would also look carefully at the MAF sensor during this test to see if it is working right.
brewder
Nov 23, 2013 01:17 PM
existence1000
Apr 8, 2013 12:47 AM
TheCounty
Dec 3, 2012 09:12 PM
monkey323i
Apr 28, 2008 11:05 PM
jlewis166
Sep 8, 2007 09:06 AM
