MMI What Is It And How Do You Update??
I was thinking of getting the latest nav disc for my '06 A6 Avant but I'm reading about the MMI and don't understand it's relationship to updating to a new dics. Do you need to update the MMI when you get the latest disc, and how do you do the update? Is it something that we can download and do it ourselves?
MMI is the "Multi Media Interface". It is the software that allows the Nav, telephone, radio, cd player, voice recognition, etc. to interface with each other and be operated by the driver. While I have heard of two people who were able to update the MMI software themselves (they had several failures before they succeeded), it is really a dealer issue. If you are in the US you want to make sure that you have MMI version 33.6 or higher.
This must be a really obvious answer, but I keep reading of version numbers as a four digit number, but I haven't been able to pick out which four digits they translate to. The top line on my car (US 2005 A6 3.2) reads: SW:C6-HU 6360 10.7.0 0437. Does that mean it's a version 1070?
Thanks!
Thanks!
Updating the MMI must be done by the dealer using the factory scan tool, you shouldn't need to update the MMI when using a newer nav disc.
Thanks!
Thanks!
So it sounds like I need to take this to the dealer for the update. I had previously asked them to make sure the MMI was up to date. Obviously I wasn't clear enough. Is there a better way to ask or a secret handshake or something? Also, is this a warrantiable item? My car is still under the original warranty, plus I have CPO coverage after that. Lastly, is there a way to know what the most current version is?
Thanks!
Thanks!
You have to complain about something wrong with the MMI in order for them to re-flash it, they won't just do it for you. So if you don't notice something wrong with the MMI or something that seems out of wack then chances are the tech won't bother.
I have a 2005 A6 with version 1070.
So where can i get the cd's to update to the latest version possible for my model?
Thanks.
You can buy the cd at you dealer's parts department and then do the update yourself, or you can just have the dealer do the update.
