Motor swap and now codes...
Old Apr 11, 2011 | 02:08 PM
OzzyLime's Avatar
Default Motor swap and now codes...
Long story short, the old motors valves punched holes in the pistons. I replaced the motor and it has 5 codes. Starts in closed loop, runs horrible, gets to open loop sputters and dies.
Codes are:
Cylinder 1 misfire
Cylinder 2 misfire
Cylinder 3 misfire
Cylinder 4 misfire
Multiple cylinder misfire
Car is:
2001 Audi A6 2.9 5V Auto.
Video of the sound and behavior I am experiencing:
http://www.youtube.com/watch?v=N6Dg8aCkWtM
Timing is dead on per cam lock and crank arrow, heads are both good so no flat lobes, firing order is correct. There is 1 small vacuum leak but covering it does not help. I have had the front end off so many times, need ideas on what to check before Friday.
I ordered a VAG cable but it won't be here until Friday. Many thanks.
Old Apr 12, 2011 | 08:04 AM
OzzyLime's Avatar
I reset the ECU, checked cam position sensors and it is still the same. I double checked that the timing is dead on and everything looks ok under the valve covers.
The only sensors not plugged in are the oil temp and aux coolant pump. There is a crack in the hard vacuum line that runs on the drivers side head (CVV system I think). Any ideas on what else I can check? Thanks.
Kraemer
Mar 30, 2020 03:14 PM
o0hmikee
Oct 24, 2011 10:19 PM
Siren
Mar 26, 2010 11:51 PM
green18
Dec 7, 2007 05:08 AM
bdub
Dec 21, 2006 03:49 PM
