MPG on A6 Avant Quattro
Old Nov 19, 2010 | 07:38 AM
aschweug's Avatar
Default MPG on A6 Avant Quattro
I am getting about 14mpg on my used 04 A6 Avant Quattro. I mostly drive in-town.
I have two questions which I think are related:
1. Why doesn't the Audi website list any recalls for my A6 when I type in the VIN? (It actually says something like VIN not recognized). I saw something about a gas tank nipple leak for my model/year? Is it possible that there are no recalls on my particular vehicle?
2. Is it possible that a previous owner had reset the transmission's computer to put it in lower gears? The car hardly "coasts" in "D". I have to use the tiptronic manual gear selector to get it into a high enough gear so that I don't feel like I am losing momentum from engine compression while going downhill. (e.g., running in D down hill, the engine starts to slow the car.)
Thanks!
Old Nov 19, 2010 | 08:15 AM
bob martin's Avatar
Your gas mileage sounds right for around town driving. The car is a tank and drinks fuel like one.
#1 - call a dealer, speak to the service department and ask them. It sounds like you are typing your VIN in incorrectly.
#2 - the Audi is a bit sportier than, say, American brands that have free-wheeling transmissions, and it will hold a gear for engine braking. However, the engine braking uses little or no extra fuel so why not let it have at it?
Old Nov 19, 2010 | 10:38 AM
chefro's Avatar
Quote:
" xxxxxxxxxxx is not recognized OR HAS NO RECALL/CAMPAIGN ASSOCIATED WITH IT. If you have additional questions, please contact your authorized Audi dealer".
As Bob said, you're better off calling a dealer. It is possible that all the recalls on your car were completed by previous owner(s).
Old Nov 19, 2010 | 02:52 PM
carelm's Avatar
What engine is in your Audi? I have a 2.8 V6 in my Avant and I'm getting about 19 mpg. This is mostly in-town and stop and go freeway driving.
Old Nov 19, 2010 | 07:17 PM
aschweug's Avatar
On the website, I am 99.9% sure that I am not typing the VIN in incorrectly. I do get the "" xxxxxxxxxxx is not recognized OR HAS NO RECALL/CAMPAIGN ASSOCIATED WITH IT". The "not recognized" bit is not very satisfying. It is possible that a previous owner completed all the recall items.
The engine is a 3.0L. I tried driving extra light to see if that would help, and I think I got 14.5 measured at the pump, almost the same as when I drive like a maniac. This is lower than what I see on the on-screen computer (~17mpg). (This discrepancy is what made me think of the gas tank recall, although I onl once had a gas smell after a fill-up.)
Thanks for your help,
AS
Old Nov 19, 2010 | 07:19 PM
aschweug's Avatar
Thanks all,
On the website, I am 99.9% sure that I am not typing the VIN in incorrectly. I do get the "xxxxxxxxxxx is not recognized OR HAS NO RECALL/CAMPAIGN ASSOCIATED WITH IT". The "not recognized" bit is not very satisfying. It is possible that a previous owner completed all the recall items.
AS
Old Nov 20, 2010 | 01:04 AM
chefro's Avatar
The estimate for your model is 16 MPG for city driving.
Having said that, you're fairly close to the "official" estimate. I would assume you go every time to the same pump, fill up until it clicks (no overfill), etc, etc. When was the last time you had a "tune-up"?
Old Nov 20, 2010 | 11:58 AM
aschweug's Avatar
I have not had an official "tune-up", but had TB service shortly after getting the car, and new tires. Just about the only things I have not changed (that I know of) are the spark plugs (Bosch) and engine air filter.
HOWEVER: The previous owner told me he did have it "tuned up because the car felt slow to him". I am wondering if something could have been adjusted to make the car stay in lower gears (consuming more gas, resulting in more downhill compression, and worse gas mileage). I am simply unaware what beside oil, filters, spark plugs, brakes can be adjusted in a tune-up.
I also suspect that my transmission may simply be old. [At 107k miles, I am too far out to do the flush.]
I don't always use the same station, but I always fill to the first click, and the numbers have been steady over the last 4 fills. I am using "Plus" gasoline. (Not really sure if that is any benefit.)
Old Nov 20, 2010 | 12:32 PM
aschweug's Avatar
Just called dealer, who ran the VIN, and who told me that there were no outstanding recall items.
Old Nov 20, 2010 | 12:38 PM
bigdadi's Avatar
The change of tranny fluid & filter and the change of differential fluid can make a noticeable difference, change the air filter also.
Audi requires special procedure (Vag-Com to monitor the liq temp & certain liquid on changing the ATF, so make sure bring it to the dealer or indy shop specialized on Audi.
I have 3.0L Avant Quat and avg 18.6mpg in avg 25 mph city driving. You can reset these numbers to zero and start over again after the changes.
