My Audi A6 2.7T BiTurbo Stage 3 ( need opinions )
nice! i'd definitely get some coilovers and loose a little of that wheel gap. a silicone hose kit wouldn't be bad way to go either. i like your set-up though. very sleeper.
what injectors, tune are you running?
Thanks man, appreciate the though, right now that's exactly what im considering, Lowering it. Right now im trying to find Exterior Opinions, what Mod's should i do on the outside?
Mainly Everything in the Engine is stock, Except for:
I Just placed 2 Diverter 007 Forge Vavles on each Turbo, sounds mean.
I am placing a Cool air Intake into it, ( KNN )
Also i just purchased a Rephrase ECU Chip which will bump the HP to 360.
do you have k04 turbos or something else? i have the forge dv's also. they are great diverter valves (you have 2 forge dv's or 4?). i wouldnt go with the k&n intake because the oil they use on there filters gunks up our MAF's. go with a dry flow filter when you get an intake.
i'm guessing you mean re-flashed ecu. where is it from? (vast, apr, awe, epl,etc)
What do you consider "Stage 3"? If you don't already have a 360 HP chip, how can you be "Stage 3"? If you don't already have coil-overs, how can you be "Stage 3"?
But, back to your question, what I would change is the car. Seriously. The A6 is a pig. You can put lipstick on a pig but its still a pig. Trade the car for a nice S4 or take the plunge for an RS6.
Bob
Bob
coil overs dont have anything to do with being stge 3, but i see where bob is going with this. i would also like to kinow what you have on your car to consider it stage 3. dv's and a stage 2 chip are a great start but you need a turbo upgrade and full fueling to be "stage 3".
anyway. check out the cupra r lip spoiler. i've seen it on a couple a6's and it doesnt look half bad. with some coilovers, rolled fenders and some wiiiiiide 18's or 19's w/ step lip'd wheels your car would look wicked. check out work vs-xx's.
