My window
Old Sep 21, 2008 | 10:50 PM
Rhino85's Avatar
SoCal Crew Member
Default My window
So I've gotten no where with searches and I've taken the door apart and can't seem to find a problem. When I have the window down all the way, I roll it up, it gets slow and the side that's towards the back gets pulled leaving the window about an 1/8" off track. It slides through the track fine, everything is greased. Here's a pic and you can see it pulled to side. The strip of un-tinted window on the side.
Any help would be great. Thanks.
Old Sep 21, 2008 | 11:05 PM
ryuuoh's Avatar
it's your widow guides, very cheap fix.
Old Sep 21, 2008 | 11:07 PM
oc_audica's Avatar
there was a writeup on this too... i'm thinking it was actually here on AF
Old Sep 21, 2008 | 11:08 PM
Jeffla's Avatar
Except the rear windows you can't just buy the replacement guide clips like you can with the front windows. You must buy a new regulator.
Jeff
Old Sep 22, 2008 | 01:36 AM
Rhino85's Avatar
SoCal Crew Member
Sounds like a fun fix :-P
Do you remember what section you might have seen the write up in? DIY?
Old Sep 22, 2008 | 10:59 AM
whitey's Avatar
the writeup for the window guides is on audiworld. Took me about 45 min to do the pass front window...never tried the back so I don't know if it's the same or not.
Old Sep 22, 2008 | 06:59 PM
Rhino85's Avatar
SoCal Crew Member
cool I'll check that site see what I can find.
Old Sep 24, 2008 | 05:57 PM
nm3210's Avatar
here if you haven't had luck so far: http://www.audiworld.com/tech/int45.shtml
Old Sep 24, 2008 | 06:46 PM
CosminTX's Avatar
good luck adjusting the door, and remember don`t rush , take your time, plan more time to put it back than to take it apart.
Old Sep 24, 2008 | 07:10 PM
Rhino85's Avatar
SoCal Crew Member
Awesome, thanks everyone. Now I just need to find the time to sit down and work it out. And yeah, anytime I mess with the car, I always take it slow, don't want to create a bigger problem than I already have.
