Need help 1999 A6 quattro
Old Jan 17, 2007 | 09:18 PM
foorausfoora's Avatar
Default Need help 1999 A6 quattro
Okay, so about 1 week ago i was driving in boston, ( i live in New Hampshire) and i was going to a celtics game. i was in stop and go traffic and i was stopped when i began to smell a light burning (rubbery) smell. i got out checked the engine/car couldnt find anything, then the smell went away when i drove, another time i was in park at a gas station went in to buy gum, came out walked in my car and smelt the same thing and checked it again couldnt find anything.
Now her is the kicker. i just got back from 5 nights in NY nobody drove my car, and it has been VERY VERY cold in NH. this morning tried to start my car. it was dead, so i jumped it and after a long time it was working. however now the check engine light is on. i can smell the buringing alot more. i saw the smoke and it looks like its from the right front side. the other BIG problem now is my car is not accelerating like usually when i floor it, it doesnt really move much at all. over the time i was gone there was a 1/5 tank of gas in the car, so i think myb it is my injector i filled up the car fully and put injector cleaner. but im very scared. anybody no what any of this stuff is. i do usually drive my car in "Triptronic" could it be my Trans. I would appreciate ANY help
Old Jan 27, 2007 | 05:03 AM
mjsell6's Avatar
Default RE: Need help 1999 A6 quattro
I just got my 1999 A6 back from the dealer last week after a similar problem (big bucks). It got real cold her in Minnesota and on my way home from work and my car started to steam. After several stops I made it home,however, had quite a bit of oil on the garage floor the next morning when I looked. It turned out to be leaks on two seperate cam shaft seals (don't know how this relates to the steaming oil--not much of a techie) There were also two smaller leaks. I would definitely have it looked at sooner rather than later. Mine has 140,000 miles. Hope this helps some--good luck.
Old Jan 27, 2007 | 11:56 PM
SouthboroAudiGuy's Avatar
The "check engine light" is a classic "idiot light" that tells you VERY little. What is DOES tell you is that the car's computer is storing a code that will provide you with much more info. To read that code out of the car's computer, you need something called a VAG COM (software that runs on your 'puter + a special cable that hooks up to your car). Some Autozones have these and will read the codes out for you. Alternatively, you can find a garage that has one and have them do it. Alternatively, you can do a search for "VAG COM locator" and find somebody who owns one year you. In any event, not much can be done to diagnose your problem without this info.
Good luck.
cougarcb16
Jun 23, 2010 06:51 PM
ZMIKEMAN
Jun 19, 2010 10:58 PM
deadeyeknight
Jan 22, 2010 02:48 PM
Shwangin
Mar 15, 2009 08:20 PM
RCFerrari
Jul 12, 2006 02:24 PM
