need help asap!
Old Jul 23, 2008 | 03:33 AM
alexfunari's Avatar
Default need help asap!
front left of my car "knocks" when I roll over bumps or turn the wheel left and accelerate slow. Knocking goes away but car kinda "shakes" a little at 50+ mph. I'm assuming its the rotor of the rip. What happened was my lug nuts came loose (didnt know at the time) one the interstate and my car was shaking for about 45 miles till I got home. Tightened them up and know I've got the knock noise.
I really honestly think its Just the rotor (one mechanic from out of town heard it and said so) but I don't know of any honest mechanics around here. I really hate going to random mechanics are they always add **** on all the time.
Thanks in advance!
anybody know a good mechanic in the sarasota / bradenton area (30 mins from tampa) aka sw florida
Old Jul 23, 2008 | 01:19 PM
wammy18's Avatar
Default RE: need help asap!
bump let me know what the issue is when you get a chance
Old Jul 23, 2008 | 02:49 PM
kimi's Avatar
i would jack up the left wheel, and rock it manually to see if i can reproduce the noise. i would wanna rule out a bad bolt joint oneither upper or lower control arms. they get driedup with agesometimesand begin playing within the joint.
Old Jul 23, 2008 | 04:00 PM
joetm's Avatar
yea id say thats ur best bet is to check ur tie rod and joints because they start to go depending on how u drive the car at about 75K+
Old Jul 24, 2008 | 07:37 PM
alexfunari's Avatar
bump, i jacked it up and it does not knock, i think it is the rotor... or am i completely wrong?
Old Jul 24, 2008 | 07:55 PM
kimi's Avatar
the symptoms of a bad rotor tend to present deferently, usually they will present with vibrations on breaking which may range from subtle to quite violent in some cases. hardly will they present with a knock after climbing a bump. bolt joint damage can be reproduced by jacking the car, and rocking the interested wheel in all planes vertical and horizontal. try having the car in normal park position, without jacking the car, pound on the interested side of the car as if you where testing for bad shocks, this may repoduce the noise.im still of the oppinoin that it is a bad bolt joint
Mmspartan
Jun 14, 2011 05:14 PM
zerodegre
Sep 20, 2009 11:33 PM
dejahn23
Sep 22, 2008 07:28 PM
bhunt17
Feb 21, 2008 07:07 AM
silveraudib6
Feb 8, 2008 04:11 PM
