Need help changing "spider pipe"
Old Feb 5, 2011 | 11:45 AM
playboy00786's Avatar
Default Need help changing "spider pipe"
Im trying to replace my spider pipe in my 01 a6 2.7 and im having a hard time trying to figure out what i need to remove in order to reach the last hose of the spider pipe thats located in the back of the crank case. Its covered up by a ton of hoses and I i need some guidance on what to remove in order to reach it. Thanks
Old Feb 6, 2011 | 08:31 AM
bob martin's Avatar
Yeah, that one is a difficult connection. IIRC (it has been a few years since I last did mine) I removed the air pump and the large hose that blocks your access. Not tough once you figure it out but the figuring takes a bit.
Good luck,
Bob
