Need help with this diagnosis
This is for a 2005 Audi A6 -Quattro-BKH
I have replaced the J757 relay, G410 sensor and N80 valve and I still get this code and there is a new code, for starter relay. Wednesday,30,September,2015,11:16:48:61835 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 15.7.1.0 (x64) Data version: 20150904 Ross-Tech: Home VIN: WAUDT74F35N047546 License Plate: Mileage: 210280km-130661mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4F (4F0) Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 72 77 VIN: WAUDT74F35N047546 Mileage: 210280km-130661miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 4F1 910 559 B HW: 4F1 907 559 A Component: 3.2l V6 FSI 0040 Revision: --H15--- Serial number: Coding: 01050106190F0120 Shop #: WSC 25807 444 54393 VCID: 2A5BE460850EA26E23-807E 3 Faults Found: 19502 - Starter Relay 1 P3046 - 006 - Electr. Malfunction in Circuit (Relay Stuck / Does not Switch) - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 35 Mileage: 210124 km Time Indication: 0 Date: 2015.09.28 Time: 18:16:39 Freeze Frame: RPM: 1152 /min Mass Air / Rev.: 141.7 mg/str Temperature: 97.5°C Idle Voltage: 11.73 V Speed: 0.0 km/h 18975 - Low Pressure Fuel Sensor (G410) P2543 - 009 - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 7 Reset counter: 40 Mileage: 210131 km Time Indication: 0 Date: 2015.09.28 Time: 19:11:55 Freeze Frame: RPM: 672 /min Mass Air / Rev.: 239.8 mg/str Temperature: 88.5°C Idle Pressure: 4.9 bar Speed: 0.0 km/h 18836 - EVAP Leak Detection Pump Sense Circuit P2404 - 006 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 4 Fault Frequency: 2 Reset counter: 40 Mileage: 210146 km Time Indication: 0 Date: 2015.09.29 Time: 09:47:38 Freeze Frame: RPM: 1312 /min Mass Air / Rev.: 114.5 mg/str Temperature: 78.0°C Idle Voltage: 13.57 V Speed: 40.0 km/h Readiness: 0000 0100 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 H HW: 09L 927 156 Component: AG6 09L 3.2 FSI USA 0020 Revision: --H01--- Serial number: 0048342 Coding: 0001002 Shop #: WSC 02335 785 00200 VCID: 29591B6C8008A9762A-807C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 E HW: 4F0 614 517 A Component: ESP8 quattro H03 0010 Revision: 00000000 Serial number: 00000000000000 Coding: 0004511 Shop #: WSC 02335 785 00200 VCID: 264310509116860E07-8072 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H30 0130 Revision: 30040401 Serial number: 10600300069238 Coding: 0000011 Shop #: WSC 25105 444 54636 VCID: 63C54944A2A4332620-8036 Subsystem 1 - Part No: 4F0 910 131 J Component: FBSAUDIC6 EZS H43 0070 Subsystem 2 - Part No: 4F0 910 220 A Component: FBSAUDIC6 IDG H35 0040 1 Fault Found: 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 55 Mileage: 210135 km Time Indication: 0 Date: 2015.09.28 Time: 21:21:00 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F0 910 732 Q HW: 4E0 035 729 Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 360IQ047504466 Coding: 0000003 Shop #: WSC 04352 001 1048576 VCID: 3169F30CA8D8D1B6E2-8064 Subsystem 1 - Part No: 4F0 910 609 Component: Bedienteil MMIC6H07 0870 Subsystem 2 - Serial number: 00000000052016 Subsystem 3 - Serial number: 0108.09.040000000100010018˙ Subsystem 4 - Serial number: 010018˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 H Component: KLIMABETAETIGUNGH11 0110 Revision: 00000023 Serial number: 00000000056135 Coding: 0524326 Shop #: WSC 02335 785 00200 VCID: 5BB571A49AD40BE668-800E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 HW: 4F0 907 279 Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0013123 Shop #: WSC 02335 785 00200 VCID: 66C350505196460EC7-8032 Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBD6007427 Shop #: WSC 00000 000 00000 VCID: 1C3732B8DF5A4CDEA1-8048 No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 B HW: 4F0 959 655 A Component: 56 AIRBAG AUDI8RH28 0310 Revision: 09H28000 Serial number: 00359D071N9R Coding: 0013622 Shop #: WSC 05141 444 83913 VCID: 264310509116860E07-8072 Subsystem 1 - Part No: 4F0 910 339 Component: BF-Gewichtsens. 002 0040 Subsystem 2 - Serial number: 6332CSME057858598 Subsystem 3 - Serial number: 6342CSME06524A0D2 Subsystem 4 - Serial number: 6351HSME036A4023 Subsystem 5 - Serial number: 6361HSME037C42523 Subsystem 6 - Serial number: 6371VSME0364180CH Subsystem 7 - Serial number: 6381VSME03755A72N No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90026042540234 Coding: 0002041 Shop #: WSC 02335 785 00200 VCID: 66C350505196460EC7-8032 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 950 M Component: KOMBIINSTR. M73 H09 0460 Revision: 00100000 Serial number: 4I275XD94 Coding: 0065263 Shop #: WSC 25105 444 84543 VCID: 1E3338B0C9465ECE4F-804A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 B Component: Gateway H09 0030 Revision: 09 Serial number: 08008048180364 Coding: 6CFE73CC1B3904 Shop #: WSC 02335 785 00200 VCID: 275D1D54961C9F063C-8072 1 Fault Found: 02230 - Digital Radio (DAB) (R147) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 15 Mileage: 210124 km Time Indication: 0 Date: 2015.09.28 Time: 18:16:47 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082946 Shop #: WSC 02335 785 00200 VCID: 61C9434CB8B8213632-8034 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 M HW: 4E0 919 887 C Component: MNS US H43 1100 Revision: 00000000 Serial number: 378IP047501450 Shop #: WSC 02335 785 00200 VCID: 387FCE284BA200FEA5-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 793 B Component: TSG FA H10 0020 Revision: 00000000 Serial number: Coding: 0035563 Shop #: WSC 02335 785 00200 VCID: 29591B6C8008A9762A-807C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 E HW: 4F0 907 289 E Component: Komfortgeraet H14 0090 Revision: 00900014 Serial number: 01000810860000 Coding: 0423997 Shop #: WSC 02335 785 00200 VCID: 2C57E2788FFABC5ED1-8078 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H02 1301 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4F5 910 223 F HW: 4F5 035 223 E Component: DSP-High C6 H14 0330 Revision: PROD_01 Serial number: 00000000007747 Coding: 0000016 Shop #: WSC 02335 785 00200 VCID: 264310509116860E07-8072 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H07 0040 Revision: Serial number: 00000000030599 Coding: 0001114 Shop #: WSC 02335 785 00200 VCID: 5EB378B089C61ECE0F-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 792 B Component: TSG BF H10 0020 Revision: 00000000 Serial number: W Coding: 0035563 Shop #: WSC 02335 785 00200 VCID: 29591B6C8008A9762A-807C No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 D HW: 4F0 907 801 B Component: EPB CEFC0090 H05 0090 Revision: --H05--- Coding: 0005022 Shop #: WSC 00001 000 00000 VCID: 2149034CF838613672-8074 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 A HW: 4F0 907 357 A Component: AFS 1 H03 0010 Revision: 00000001 Serial number: Coding: 0000016 Shop #: WSC 02325 785 00200 VCID: 24470A58E72A741E19-8070 Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH05 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 352IU047556615 Coding: 0000002 Shop #: WSC 02335 785 00200 VCID: 3169F30CA8D8D1B6E2-8064 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H11 0490 Revision: 00000000 Serial number: 00000000051399 Shop #: WSC 04352 001 1048576 VCID: 23450944E224732660-8076 Subsystem 1 - Part No: 4F0 915 105 C Component: von VA0 1409090118 Coding: 344630393135313035432056413031343039303930313138 Shop #: WSC 12345 640 00290 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 HW: 4F0 959 795 Component: TSG HL H09 0010 Coding: 0035370 Shop #: WSC 02335 785 00200 VCID: 69D95B6C40886976EA-803C No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 HW: 4F0 959 794 Component: TSG HR H09 0010 Coding: 0035370 Shop #: WSC 02335 785 00200 VCID: 69D95B6C40886976EA-803C No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 H HW: 4E0 862 335 Component: Handyvorb2 H10 1130 Revision: 00000000 Serial number: 00000007501395 Coding: 0010900 Shop #: WSC 00000 000 00000 VCID: 285F1E689B02907E35-807C No fault code found. End-------------------------(Elapsed Time: 02:48)-------------------------- |
Ive S7 that i changed plugs in. The car wasnt running real good before and a mechanic friend said to change plugs. Now the car is running worse and throwing a P2541 code Low pressure fuel sensor (G410) Short to ground. Any ideas?
It's better go to the reliable service with all this and not ask on forums
I don't think even a 1/4 of the people from this forum can understand that code. And even if they do, I'm sure no one can really help you. With such a problem you should consider going to a repair shop. There are the right people to help you with the issue. When my car started showing lousy coding, I immediately took it to a repair center. They were using https://autoleap.com software, so it was easy to find out where the problem was and how to fix it. I hear that nowadays most shops use it. Perhaps you can call some repair shops and ask if they can help you out.
Hi, Have you removed all fault code and done a fresh scan? Also is your VCDS legit or copy? Have you checked that you are getting any signal or power to the relay and was the relay genuine vag part? Even new stuff can be faulty.
Cheers |
