Need help with this diagnosis
Old Sep 30, 2015 | 12:48 PM
bballfreak's Avatar
Default Need help with this diagnosis
This is for a 2005 Audi A6 -Quattro-BKH
I have replaced the J757 relay, G410 sensor and N80 valve and I still get this code and there is a new code, for starter relay.
Wednesday,30,September,2015,11:16:48:61835
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Ross-Tech: Home
VIN: WAUDT74F35N047546 License Plate:
Mileage: 210280km-130661mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 72 77
VIN: WAUDT74F35N047546 Mileage: 210280km-130661miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0040
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 25807 444 54393
VCID: 2A5BE460850EA26E23-807E
3 Faults Found:
19502 - Starter Relay 1
P3046 - 006 - Electr. Malfunction in Circuit (Relay Stuck / Does not Switch) - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 210124 km
Time Indication: 0
Date: 2015.09.28
Time: 18:16:39
Freeze Frame:
RPM: 1152 /min
Mass Air / Rev.: 141.7 mg/str
Temperature: 97.5°C
Idle
Voltage: 11.73 V
Speed: 0.0 km/h
18975 - Low Pressure Fuel Sensor (G410)
P2543 - 009 - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 7
Reset counter: 40
Mileage: 210131 km
Time Indication: 0
Date: 2015.09.28
Time: 19:11:55
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 239.8 mg/str
Temperature: 88.5°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
18836 - EVAP Leak Detection Pump Sense Circuit
P2404 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 210146 km
Time Indication: 0
Date: 2015.09.29
Time: 09:47:38
Freeze Frame:
RPM: 1312 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 78.0°C
Idle
Voltage: 13.57 V
Speed: 40.0 km/h
Readiness: 0000 0100
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0048342
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 29591B6C8008A9762A-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004511
VCID: 264310509116860E07-8072
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0130
Revision: 30040401 Serial number: 10600300069238
Coding: 0000011
Shop #: WSC 25105 444 54636
VCID: 63C54944A2A4332620-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H35 0040
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 210135 km
Time Indication: 0
Date: 2015.09.28
Time: 21:21:00
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 360IQ047504466
Coding: 0000003
Shop #: WSC 04352 001 1048576
VCID: 3169F30CA8D8D1B6E2-8064
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000052016
Subsystem 3 - Serial number: 0108.09.040000000100010018ÿ
Subsystem 4 - Serial number: 010018ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000023 Serial number: 00000000056135
Coding: 0524326
VCID: 5BB571A49AD40BE668-800E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
VCID: 66C350505196460EC7-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6007427
Shop #: WSC 00000 000 00000
VCID: 1C3732B8DF5A4CDEA1-8048
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH28 0310
Revision: 09H28000 Serial number: 00359D071N9R
Coding: 0013622
Shop #: WSC 05141 444 83913
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME057858598
Subsystem 3 - Serial number: 6342CSME06524A0D2
Subsystem 4 - Serial number: 6351HSME036A4023
Subsystem 5 - Serial number: 6361HSME037C42523
Subsystem 6 - Serial number: 6371VSME0364180CH
Subsystem 7 - Serial number: 6381VSME03755A72N
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026042540234
Coding: 0002041
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H09 0460
Revision: 00100000 Serial number: 4I275XD94
Coding: 0065263
Shop #: WSC 25105 444 84543
VCID: 1E3338B0C9465ECE4F-804A
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008048180364
Coding: 6CFE73CC1B3904
VCID: 275D1D54961C9F063C-8072
1 Fault Found:
02230 - Digital Radio (DAB) (R147)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 15
Mileage: 210124 km
Time Indication: 0
Date: 2015.09.28
Time: 18:16:47
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 61C9434CB8B8213632-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H43 1100
Revision: 00000000 Serial number: 378IP047501450
VCID: 387FCE284BA200FEA5-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: ‘
Coding: 0035563
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000810860000
Coding: 0423997
VCID: 2C57E2788FFABC5ED1-8078
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000007747
Coding: 0000016
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000030599
Coding: 0001114
VCID: 5EB378B089C61ECE0F-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: W
Coding: 0035563
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0005022
Shop #: WSC 00001 000 00000
VCID: 2149034CF838613672-8074
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 A HW: 4F0 907 357 A
Component: AFS 1 H03 0010
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 02325 785 00200
VCID: 24470A58E72A741E19-8070
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH05 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352IU047556615
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000051399
VCID: 23450944E224732660-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1409090118
Coding: 344630393135313035432056413031343039303930313138
Shop #: WSC 12345 640 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: 69D95B6C40886976EA-803C
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007501395
Coding: 0010900
VCID: 285F1E689B02907E35-807C
End-------------------------(Elapsed Time: 02:48)--------------------------
Old Jan 4, 2022 | 10:39 AM
BartB's Avatar
Ive S7 that i changed plugs in. The car wasnt running real good before and a mechanic friend said to change plugs. Now the car is running worse and throwing a P2541 code Low pressure fuel sensor (G410) Short to ground. Any ideas?
Old Jan 26, 2022 | 09:34 AM
Carmassi's Avatar
It's better go to the reliable service with all this and not ask on forums
Old Jan 28, 2022 | 02:56 AM
Cobailer's Avatar
I don't think even a 1/4 of the people from this forum can understand that code. And even if they do, I'm sure no one can really help you. With such a problem you should consider going to a repair shop. There are the right people to help you with the issue. When my car started showing lousy coding, I immediately took it to a repair center. They were using https://autoleap.com software, so it was easy to find out where the problem was and how to fix it. I hear that nowadays most shops use it. Perhaps you can call some repair shops and ask if they can help you out.
Old Mar 19, 2022 | 11:16 AM
alanhodges's Avatar
Hi, Have you removed all fault code and done a fresh scan? Also is your VCDS legit or copy? Have you checked that you are getting any signal or power to the relay and was the relay genuine vag part? Even new stuff can be faulty.
Cheers
thavinci
Jan 27, 2022 02:33 PM
WatervilleImport
Audi Q7
Apr 28, 2017 10:20 AM
Ahmcam
Jun 14, 2015 12:27 PM
eazy211187
Dec 30, 2012 04:53 PM
Tom$lick
May 24, 2009 08:17 PM
