Need help please. 2000 A6 Hazard Relay Replacement
Old Jan 31, 2010 | 05:06 PM
Cisco's Avatar
Default Need help please. 2000 A6 Hazard Relay Replacement
I just bought a 2000 A6 wagon. The turn signal relay started to go out, and is now completely gone, nada. I understand I have to pop the dashboard panel off around hazard light relay and replace it, which has the turn signal relay in it as well.
Ok, how do I do this, step by step?
What tools do I need?
Is there a schematic of the dash, would it be helpful?
Thanks in Advance.
Old Feb 2, 2010 | 11:37 AM
hxgaser's Avatar
Dang, no one? I guess I will get off my **** and take a stab.
1. Remove the wood trim. Use a flat head screw driver on the right or left hand side and lift to opposite side. Do not pull from the top or the bottom, since you may break some plastic tabs.
2. remove the cup holder and/or the tray to the left. There is a wiring connector behind each one of those. You just disconnect it.
3. The hazard relay is held with 2 spring type metal pins, one on each side. Just stick a screw driver in from the left or right, and squeeze the pins. See Picture below.
4. Disconnect the wiring are replace it.
When I did mine, a couple of metal tabs held by plastic on the wood trim broke. Superglue worked fine.
Old Feb 2, 2010 | 05:28 PM
catdog's Avatar
What Hxgaser said. I did break some tabs that hold the wood trim. It still fits snug. Careful not to scratch the cupholder paint. Maybe some tape on anything that could get scratched.
0956JLee
May 20, 2013 08:19 AM
audiaxel
Apr 23, 2013 02:30 AM
catdog
Nov 8, 2009 01:13 AM
randomloginname
Apr 1, 2008 11:13 PM
modset
Feb 26, 2008 06:51 PM
