Need source for headlight connector pins
Old Jul 31, 2012 | 11:16 PM
TENA6NUT's Avatar
Default Need source for headlight connector pins
Hi,
Working on converting halogen headlights to factory HID's on 2002 A6. I need to increase the low beam wire size from 1mm to 1.5mm wire size. I need to locate some new pins for the headlight harness connectors to crimp onto the new wire and insert into the connector. There are two 10-pin connectors for the wire harness for each headlight, one with two rows of 5-pins at the headlight and another that is a pink colored connector at the connector junction at the A-pillar. The pink connector is an AMP brand connector. I am able to find tools to remove the pins from the connectors but I can't locate replacement pins for either connector. Anybody know where to get them?
thanks
tj2k11
Apr 17, 2014 10:52 PM
da_Rayman
Nov 14, 2013 01:33 PM
ImTheDevil
Jan 29, 2013 11:09 PM
phatboyfromla
Dec 6, 2010 08:38 AM
blue2
Jun 17, 2005 05:11 PM
