Need Xenon converter HELP
any help is good
I have an a6 01 2.8, and im planning to take a road trip during chirstmas. its a 12 hour drive. Well what i am asking is; i have the regular bulb headlights. I was wondering if i convert them to xenon, would they give a better lighting. I also need to buy fog lights since i had to take them off because of a previous accident.
I have looked at ebay and saw at some ballast converters I dont want to waste too much money like 150 or more or i dont want to buy cheap ones because they break easily
anyone have any suggestions???????? also with the fog lights, i want to try to have them the same color, passing threw mountains, its alot of fog
Another question is, what kind of bulb do i get????? do they come with the conversion kit???
now i think my car uses an h7, but when i see the HID bulb, it looks really different
well imjust asking since the old bulb usually goes in the headlight easily.... will the new bubls be like that too?
LeAudi19, according to the Sylvania bulb guide, a 2001 A6 uses a H1 bulb for low beam and a H3 for fog lights. You need a rebase HID kit so the HID bulb will fit into your halogen hosuing. Try this site right here, they have very good customer support:
http://www.kbcarstuff.com/4300k_Xtre...&category_id=2
Type in CL for a discount code and you will get 10% off.
whatever you do dont get a cheap kit off ebay.. id know from previous expierence many times with those in the past.. ive found that DDM makes a really good 55 watt HID system and ive had em for 2 years without problems. id recommend them...
http://ddmtuning.com/hidkihidbuhi.html 55watts would be the best option.. 6 times the light and same price.. go 4500k for each bulb set if you do your fogs too.
Just beware of this limitation (in red):
What is the difference between 55w and 35w kits?
Our 55w HID kits are 40% brighter than the standard 35w kits.The 55W system ballasts are about 1 cm longer than the 35W ballasts. 55w kits tend to wash out some of the color of the HID bulb due to the light output( for example, a 55w 8000k will look similar in color to a 35w 6000k kit).55w Kits are not recommended for smaller fog light housings because they tend to concentrate a large amount of heat in a small area
Well, ive decided to go with the 35 W,
I live in Chicago and its for sure one of the most limited cities in the US,
And for sure i dont want to have to pay a $200 ticket for some lights
im just going on a road trip and need that estra light, and because I like Xenon alot
But i read in another thread that 99.5+ cars use a h7 fiting for the headlights????
the h1 looks way off, and i doubt it would fit in place
Well I ordered ones that some other people recomemded for $100
