New Front Grill for my A6
Old Jan 6, 2008 | 01:40 PM
  #21
dmrdennie's Avatar
Default RE: New Front Grill for my A6
I kinda like the 4 rings too. Has anyone seem a blacked out grill with rings ?
Old Jan 6, 2008 | 06:19 PM
  #22
A6 Quattro V6 30V's Avatar
Which body chioce do you chose C4 or C5??
I have a 99
Old Jan 6, 2008 | 08:31 PM
  #23
formulagigi's Avatar
c5 A6 narrow body, Face Lift
Old Jan 6, 2008 | 08:35 PM
  #24
ORIGINAL: cr!mz
next step clear corners ?
First I will put on my Euro plate, it is on its way, I got the Tracking email yesterday.
Then I will do the clear corners if i can find an easier way to do it than removing all the crap to get the headlights out on the write up I saw on AW. Not up for that. I might smoke the forn headlights just a bit to get a better match with the grill and plate... Like the Jetta on the pics below. I am uploading them now.
I am definitely going to smoke the tail lights though
Old Jan 6, 2008 | 08:37 PM
  #25
ORIGINAL: dmrdennie
Yeap saw one, it is my goal but am not sure hot to get to that. Just saw a pic.
But this front grill was affordable and a easy mod. You could try and smoke the rings and ege of a stock grill I guess.
Old Jan 6, 2008 | 08:46 PM
  #26
Ok here are better pics taken in the daylight! Notices the stockies are on Wheels really make a car!!
Old Jan 6, 2008 | 08:57 PM
  #27
Jeffla's Avatar
If I can make a suggestion, remove the chrome from the lower grill. Otherwise I really like the look.
Old Jan 6, 2008 | 09:49 PM
  #28
Yup, that is the plan! Actually I want all the chrome on the car gone!
Old Jan 6, 2008 | 10:08 PM
  #29
Install is about 15 minutes, clips on stock grille were a little hard, and all those plastic clips are easy to break so I had to use strength but very carefully to remove the stock grille. It made it out ok, as long as I ahe all gthe 4 upper and 2 side clips set and pushed out a bit. OEM grill is of good quality and much heavier than the replacement one. Grille comes out toward the front and upward.
Putting the grill in and getting the hood ltach on was abit tricker, it took a lot of pushing and adjusting to get the lowe clips situated right beofre I push on the top and side to snap it in. It is not that bad though.
Old Jan 6, 2008 | 10:10 PM
  #30
Jeffla's Avatar
Should have read your 1st post more carefully. Thought it seemed stange you were leaving the lower grill chrome. I like the look so much I think I might get a new grill for my A6.
