Newbie here...Driver information display
Old Jan 9, 2007 | 12:59 PM
pkhuman78's Avatar
Default Newbie here...Driver information display
I'm sure this issue has been addressed several times before, but I could not locate the information. I have a 2000 A6 2.7T and the driver's information screen has almost completely went out. What kind of options are out there for fixing / replacing this item? Does anyone know of a supplier outside of an Audi dealership? Thanks for the help.
Kevin
Old Jan 9, 2007 | 01:05 PM
tobybul's Avatar
Default RE: Newbie here...Driver information display
When you say supplier, are you referring to a parts place? Theres tons of them online. If you know the part you are looking for, ypu can usually find it on the net.
Old Jan 10, 2007 | 01:07 PM
Boston Driver's Avatar
Well, unfortunately you cannot replace just the center display...you must replace the entire instrument cluster. As such, you cannot really buy a used one since the odometer is locked andnot programmable. If you buy a "refurbished" one from the dealer, you can program the miles so your odometer is accurate to the car's actual mileage.
The cost is about $700-800 for the enw cluster, minus a core charge of a few hundred for your old cluster (you turn in your old one to get the core charge back), for a net of $400-500. It is a DIY (since you are 2000 you do not ahev to worry about prgramming the immobilizer), but you will need access to someone with a VAG COM to program the correct mileage as soon as it is installed.
Here is a great tech article on how to do this replacement yourself:
http://www.audiworld.com/tech/elec106.shtml
audiq5driverinfod
Jan 26, 2020 04:33 AM
hauptjr
Feb 23, 2010 01:18 PM
twiceborn00
Oct 21, 2009 11:22 PM
D-Roc
Nov 6, 2008 11:39 PM
skabarbie101
Jan 25, 2007 05:56 PM
