(O) still on... what's the fix if you've closed the sensors circuits?
Old Aug 27, 2010 | 05:24 AM
a6forever's Avatar
Unhappy (O) still on... what's the fix if you've closed the sensors circuits?
(O) light still on... 1999 A6Q, AHA 2.8L, changed front(w/ sensors) & rear rotors & pads. (O) still on...my question is "does connect onto a relay under/behind the driver knee bolster?" if so, which one? I've seen super fixes on here before & would like to restore without jumping wires, etc. in other words, who has tracked this back & found the culprit?
Old Aug 27, 2010 | 08:22 AM
padog's Avatar
It may be as simple as a bad brake pad the first thing I would do is check the connection in the brake pad with a multimeter.
Old Aug 27, 2010 | 01:48 PM
a6forever's Avatar
Bump:... i eliminated the pad by doing a test & closing the circuit on the car side connector by inserting a u-shaped wire stripped on each end into the connector. it's got to be something upstream. im sure there is a member that recently fault this battle i just hope he or she is listening.
Old Aug 27, 2010 | 04:09 PM
NH_USA's Avatar
check the ground wires ---
trickyniki02
Mar 26, 2010 10:10 AM
cms_45
Aug 6, 2008 03:14 PM
lakesailor
Feb 16, 2007 05:24 PM
onepoint8tee
Oct 4, 2006 02:56 PM
cdf619
Nov 28, 2005 08:59 PM
