OBD port not functioning
Old Apr 22, 2006 | 01:59 PM
beefski's Avatar
Default OBD port not functioning
Took my 96 a6 wagon in for inspection, here in NY they just plug into the data port. They plugged in their obd scanner and got no data from the car.
I had the car vag comed a year ago for a cel and there was no trouble at all. Since then it has never been used again.
The tech at the shop tested all the fuses and everything was fine. The data port is in the center console behind the cig lighter.
Is this a common problem? Anybody have any advice?
Thanks.
Old Apr 22, 2006 | 02:34 PM
dankhound's Avatar
Default RE: OBD port not functioning
Do you have an aftermarket radio? Thats the most common cause of a databus failure.
Old Apr 22, 2006 | 02:46 PM
beefski's Avatar
thanks for the reply, dankhound. I have the stock radio, but I had to do some wiring repairs to bring things back to stock. There was an aftermarket system in the car and I am bringing it back to stock. I only worked on speaker wiring nothing else.
Does the center console come out?
Is there any way to test the data port, with like a probe or something like that?
My inspection is up on monday so i'm in a bind.
Old Apr 22, 2006 | 03:12 PM
techbod's Avatar
some scanners wont work on Audi, to check if power is getting to the comms link pin 16 is +/live and pins 6 shielded ground pin 4 is ground chances are you will need it VAGed
Old Apr 22, 2006 | 03:20 PM
beefski's Avatar
thanks avant, i am trying to get in touch with somebody in my area with a vag com. I used the vag com locator and sent the guy a e mail. hopefully it is their scanner, but it would be strange since it is for the nys vehicle inspections. if i have to bring it to a shop i will pass on your info.
thank
Old Apr 23, 2006 | 04:54 PM
beefski's Avatar
What kind of tester can I use to check if I'm getting power to the port?
tom.rotramel
Jul 18, 2013 02:02 PM
Mikefc626
Aug 30, 2010 10:49 PM
AUDI5K
Sep 16, 2008 07:51 PM
2606421a
Jun 25, 2007 03:09 PM
neo283
Nov 9, 2005 04:49 PM
