oil change
Old Jul 1, 2007 | 01:30 PM
Polka Salad's Avatar
Default oil change
Just a quick question. My car doesn't have a sticker for when it needs another oil change. Does the center display tell me when I need one? Just want to make sure I dont miss it
Old Jul 1, 2007 | 01:35 PM
auditech79's Avatar
Default RE: oil change
Depends on the engine, what year it was made, and what oil your running. If your running conventional oil then every 3k is a must. Full synthetic you can get away with 5k intervals.
If you have been getting it serviced by the dealer they set the intervals at 10k which i don't recommend.
Old Jul 1, 2007 | 01:36 PM
jj2345's Avatar
ORIGINAL: Polka Salad
dont really know which year audiyou got but my 99 a6 does
Old Jul 1, 2007 | 01:59 PM
vrso2's Avatar
your center display will show "oil change" or "service inspection".
Old Jul 1, 2007 | 02:31 PM
project13's Avatar
Dumb question, I just rolled over 70K and it started with the 300, 200, 100 miles to service warning, now just pops up service, Can I take that off my self, Dealer/Vag Com only?
Old Jul 1, 2007 | 02:32 PM
mine is a 99 A6 also and I don't know when it was last serviced (i have only had it for a month or so) hense the ?...thanks
Old Jul 1, 2007 | 04:02 PM
auditech79's Avatar
ORIGINAL: project13
You can manually re-set it by pressing and holding the right **** on the cluster, turn the key to the on position, then while still holding theright **** down push theleft **** in and you should see the cluster change to either 10000 or you will see -----.
Old Jul 1, 2007 | 04:35 PM
project13's Avatar
ORIGINAL: auditech79
ORIGINAL: project13
You can manually re-set it by pressing and holding the right **** on the cluster, turn the key to the on position, then while still holding the left **** down push the right **** in and you should see the cluster change to either 10000 or you will see -----.
Do u mean holding down the "left" ****?then the key.....
Old Jul 1, 2007 | 04:39 PM
auditech79's Avatar
No i mean the right **** then the key, i don't know whatever works, damn dislexia[:@]
Old Jul 1, 2007 | 04:41 PM
project13's Avatar
Hopefully I can get it figured out
