Oil in Intercooler Ducting and EGR Valve !!!
Subscribe
Dec 14, 2007 | 11:19 AM
Recently I noticed some oil in the intercooler ducting and also coming out of holes either side of the EGR valve of my 2002 A6 Tdi SE. I proceeded to strip and clean all the affected areas. I didn't bother with the inlet manifold as I just wanted to see if the oil was residual or would it re-appear after cleaning. To my dismay, it re-appeared and therefore getting past seals in the turbo or maybe somewhere else. I also topped up the oil today as it was getting low and this made me think that I maybe losing oil through this fault. The car has done over 100K so it's safe to assume that some oil will be burnt but not at this rate considering I only carried out a service a couple of months ago. Does anyone have any ideas on this one.
Cheers,
JJ.
Reply
Dec 14, 2007 | 11:25 AM
RE: Oil in Intercooler Ducting and EGR Valve !!!
possibly a blocked vent pipe or failed PVC valve
Reply
Feb 28, 2012 | 04:34 PM
oil in egr
Ive got a similar problem bt my cars an 1.9TDI 2003. i cleaned out the egr valve and intercooler pipes twice but the oil came back so ive now been told to check to see if theres any play in the turbo fan as it sounds like the turbos on its way out
have you checked the turbo?
Reply
Feb 28, 2012 | 05:02 PM
*MOST OF THE TIME* i have noticed the PCV gets clogged when the weather out is cold and the car has been sitting outside.
check your turbo for play as mentioned. or listen for the dentist drill or siren.
Reply
Feb 29, 2012 | 06:02 PM
Quote: *MOST OF THE TIME* i have noticed the PCV gets clogged when the weather out is cold and the car has been sitting outside.
where will i find the PCV on my car A6 1.9TDI 2003 any idea?
Reply
Subscribe
