Oil Leaking from Oil filler cap
98 A6 Quattro 30V, 151K
I have oil leaking out of the oil filler cap. I have replaced the rubber gasket and the oil filler cap itself. Any ideas as to what else could be causing the leak? Is this a common issue? There was not leak for months after I replaced the cap but the leak is back.
Audi release a new oil cap a couple years back that solved this issue. It vents properly. I had to change mine a year or so ago, my pcv system was plugged, and after changing that, it got better but still leaked. I picked up the new oil cap and the problem was solved. @ your mileage, replace both.
see here :http://www.partsgeek.com/catalog/199...ther_hose.html
It does, but not in the traditional sense.
Yes.
I replaced the breather hose and the oil cap and no longer had a leaky oil cap.
I find it odd your new oil cap is still leaking. Is it leaking around the seal, or out the breather hole in the top of the oil cap?
