Oil Leaking from Oil filler cap
Old May 17, 2010 | 01:09 PM
copper07's Avatar
Default Oil Leaking from Oil filler cap
98 A6 Quattro 30V, 151K
I have oil leaking out of the oil filler cap. I have replaced the rubber gasket and the oil filler cap itself. Any ideas as to what else could be causing the leak? Is this a common issue? There was not leak for months after I replaced the cap but the leak is back.
Old May 17, 2010 | 01:15 PM
NH_USA's Avatar
How much oil is leaking?
If it is just a little - live with it
If it is a lot begin looking for a stuck PCV valve or excessive wear on the cylinder walls causing blowby.
Old May 17, 2010 | 01:31 PM
copper07's Avatar
I can smell the oil burning and I can see the leak from the cap.
Old May 17, 2010 | 01:49 PM
Jeffla's Avatar
Audi release a new oil cap a couple years back that solved this issue. It vents properly. I had to change mine a year or so ago, my pcv system was plugged, and after changing that, it got better but still leaked. I picked up the new oil cap and the problem was solved. @ your mileage, replace both.
Old May 17, 2010 | 03:17 PM
copper07's Avatar
I replaced the oil cap with the new one and I am still getting the leaks. Also I tried to see if the pcv valve was bad and I was told that the car did not have one.
Old May 17, 2010 | 04:27 PM
Jeffla's Avatar
It does, but not in the traditional sense.
see here :http://www.partsgeek.com/catalog/199...ther_hose.html
Old May 21, 2010 | 05:19 PM
copper07's Avatar
So you replaced this part on your car and you didn't have issues anymore?
Old May 22, 2010 | 12:00 AM
Jeffla's Avatar
Yes.
I replaced the breather hose and the oil cap and no longer had a leaky oil cap.
I find it odd your new oil cap is still leaking. Is it leaking around the seal, or out the breather hole in the top of the oil cap?
Old May 24, 2010 | 01:12 PM
copper07's Avatar
It is leaking out of the seal.
Old May 25, 2010 | 12:14 PM
nemohm's Avatar
There are vented caps that function as pcv - open air.
