Plastic around steering column
Old Oct 21, 2007 | 09:28 PM
catdog's Avatar
Default Plastic around steering column
How do you remove the plastic cover on the steerting column? I see 2 holes on the bottom piece. Are these small screws? Is anything else holding it on?
Mine is scratched up pretty good around the ignition. I'm thinking about removing and painting it.
Old Oct 21, 2007 | 11:11 PM
dankhound's Avatar
Default RE: Plastic around steering column
There are two screws that go up into the colum in those holes. They will be either phillips or a very small torx. There is also a screw on the bottom of column. Its behind the mechanism that locks the steering wheel. If you pull the lever down youll see the allen. There may also be a screw behind the steering wheel.
Old Oct 22, 2007 | 12:10 AM
auditech79's Avatar
Yeah you have to pull the air bag out, then the entire steering wheel to gain access to all the bolts to pull out the steering column cover.
Old Oct 22, 2007 | 09:17 AM
catdog's Avatar
This is only the 2 plastic pieces that surrond the column, the bottom has the hole for the key and theycoverthe turn signal and wipers lever/switches. Do you really have to remove the wheel and airbag just to take those off? Not sure I'm up to that.
Maybe the scratches aren't that bad.
'oooo'
Apr 11, 2010 10:27 PM
slcrobo
Oct 22, 2009 06:35 PM
Lastb0isct
Feb 17, 2009 03:15 PM
TOMMYTREETRUNK
Aug 22, 2008 05:50 AM
EnviedA6
Jun 6, 2007 07:25 PM
