Please help!!!!!!!!!!!
I have a 2000 audi a6 2.7t and it is running warm. It does not overheat but it will go to the line after the middle and stay there. I just changed the water pump a month ago. Checked all my fluids and nothing was low. Can someone please shed some light on what this might be please. Thanks!
I didn't want to burp the system after I repalced TB water pump, thermostat etc. My car would be one tic above the middle line when I first started it for a few minutes. What I did is un screwed the cap of the expansion tank every time I parked the car. It bubbled up every time (it will because of the temp change) but after 4 or 5 times it drew out the air in the system out and its all good now.
There is a chance you may have the wrong thermostat too. Always make sure to check the part number. Did you change the thermostat with the pump?
