is it possible to install keyless start button?
Old Nov 20, 2007 | 03:42 PM
topj's Avatar
Default is it possible to install keyless start button?
Is it possible to install a keyless start button that are in the later audi models in a earlier one?
Old Nov 20, 2007 | 03:54 PM
techbod's Avatar
Default RE: is it possible to install keyless start button?
yes but you still need the key to unlock the steering
Old Nov 20, 2007 | 04:21 PM
topj's Avatar
o then that sucks, no point of even putting one in then
thanks tho
Old Mar 29, 2008 | 02:39 PM
mattsaudi90's Avatar
Thread from the dead....
Anyhow, may I ask.... Why would you want to do this? With a somewhat flashy car (A6) it would just make stealing it as easy as busting out the window, unlocking the door, and vroom.
Old Mar 29, 2008 | 05:01 PM
Slurm's Avatar
you have to have the key on you for the ignition to work
Old Mar 30, 2008 | 09:55 AM
RedShoeRider's Avatar
I'm speaking a little hypothetically here, but...
It would be possible. To keep from having to use the key to unlock the steering column, you could remove/cut the locking pin that keeps the column from moving. You'd then need some type of encoded key-fob system that's tied into the ignition system, so that you have to be within, say 10 feet of the car to allow it to start, otherwise the whole thing is just a massive security risk. You could use an aftermarket remote starter kit to do the actual starting procedure; either rig the "start" button to the keyfob, or hack the remote starter unit to allow it to accept a wired connection.
There might be a way to adapt whatever module they use in later cars to the bus on on the older car, thus allowing you to use some of the factory parts without all of the hacks, but either way, it would be a crapton of research.
-Red
Old Mar 30, 2008 | 10:47 AM
Kevin's Avatar
I have the keyless start on my 05 4.2. It will only start if the fob is inside the car. It will not start even if the fob is held up to the outside of the car window. So I don't think that it ismuch of a security risk.
Old Mar 30, 2008 | 12:43 PM
murdermakescents's Avatar
i have keyless start and if the key isn't in the ignition, when you press the brake to shift, the car dies. same if you let idle for about a minute with no key.
biker
Feb 25, 2018 03:56 PM
audi-here
Aug 5, 2013 04:51 AM
peanut butter
Feb 21, 2012 02:15 PM
aerostatwv
Dec 20, 2009 09:27 PM
engfrank
B8 Models
Jun 15, 2009 10:17 PM
