Problematic sound, any idea?
Old Apr 21, 2022 | 03:33 PM
dsaran's Avatar
Default Problematic sound, any idea?
Dear all,
There is a sound file of my 2008/2009 A6 C6 3.0 TDI as attachment. I recorded it from my engine area while the hood is open. Injectors sound are major source of sound but the problematic sound exist also.
If is there anybody to diagnose the source of sound (may be heard before?), I'll be appreciated.
Regards
File Type: mp3
Old May 14, 2022 | 01:38 PM
Tom_Mach's Avatar
Sounds like timing chain. Does it go away after a while? Could also be VVT Sprocket. I had right side go bad and had all 4 replaced along with upper timing tensioners.
Old May 17, 2022 | 04:04 PM
dsaran's Avatar
Replaced my timing chain and tensioners 6 months ago. Btw what is the VVT Sprocket lifetime and change interval? My car is on 415K km and engine was refurbished at 400K km.
Actually I tried to put video at first but it was not allowed. May be i should upload the video to google drive or youtube and share the link here later.
Old May 18, 2022 | 06:26 PM
Tom_Mach's Avatar
I'm not sure if the VVT have a specific service time. Mine were causing a "tapping" sound on the right side (US passenger) which would go away from 2-7 minutes after startup and idling. Since it was under warranty I took it in for service. The Tech showed me the issue by manually rotating each "Phaser" (VVT Sprocket) and you could hear it click and others were not rotating smoothly so he said they all should be replaced. Car only had 132K Miles. Since the tensioners are known to go bad he also replaced the uppers since the guides were wearing down. Car was fine for almost a year and now I'm getting a rough idle and a code not listed in the public Audi list of codes with my VAG. I tested my cam sensors which were fine but i found an oil leak on the right timing cover and figured i take a closer look. Found the tech didn't properly torque the bolts properly on either the cover or tensioner so I replaced it with a new gasket to stop the leak. still didn't resolve my code though which i have asked for help on the forum with no response so far.
andybenjami
Mar 4, 2013 04:10 AM
austindgarner
Apr 23, 2010 05:38 PM
Bien32
May 16, 2009 12:25 AM
NuYorka103185
Jan 23, 2007 09:25 PM
apg96
Mar 9, 2005 01:46 AM
