Proper rotor size for 3.0 avant?
My favorite parts guy recently told me he has 3 thickness dimensions (255, 256, and 269) listed for the rear rotors on my 2002 3.0L wagon. Does anyone know what the proper dimension is or how to determine? The current ones are pretty worn so I can't imagine you could get an accurate reading.
Thanks in adv. |
You have a VIN, right?
Pick up the phone and ask the dealers! In any case: Front 321x30mm 312x25mm w/ ATE Calipers --------------------------------- Rear 255x10mm - 53.8mm Height - w/ 1570mm Axle Width & 82mm Bearing **BUILD CODE PR-0N5** 255x10mm - Sedan - w/ 1558mm Width Axle **BUILD CODE PR-0N6 = Rear Axle Width 1558mm, 82mm Wheel Bearing** ***Brake Disc Dimensions 47.8mm Height/255mmx10mm 5/112*** Vehicles with tire sizes: 215/55 R 16" 225/45 R 17" 235/45 R 17" 235/40 R 18" |
