Pulled my codes using VAG, Cyl's 3 & 6 misfire
Old Oct 20, 2010 | 04:39 PM
BostonSims's Avatar
Default Pulled my codes using VAG, Cyl's 3 & 6 misfire
Attached is the log from my VAG scan. It says there is a misfire from both cylinder 3 & 6. If i remember correctly they are powered by the same thing but i cant remember, how would i test that? I already know that i have to replace o2 sensor 1 in bank 1. But as for the cylinder misfires, what should i do to diagnose further using my vag? or otherwise. thanks
Old Oct 20, 2010 | 06:18 PM
nemohm's Avatar
Swap spark plugs and ignition coils between cylinders. One swap at a time.
Monitor if the misfire follows the parts from cylinders at fault. And vice versa - faulty cylinders are ok with the new parts.
Note that there was an ignition coil recall - free replacement- check it with your dealers.
Old Oct 20, 2010 | 07:15 PM
BostonSims's Avatar
i already swapped with brand new plugs, dealer claims my model doesnt fall under recall for coils. anything else if not the coils and plugs?
99A4BlackNGrey
Jan 19, 2009 10:59 PM
audi_n00b
Jan 8, 2009 10:40 PM
socalaudi
Jan 8, 2008 11:56 AM
qttrcoupe
Oct 26, 2007 04:36 PM
bmwtoaudi
Feb 22, 2007 11:18 AM
