Push button start
Push start sometimes it starts sometimes it doesn't. Sometimes you can't start with key and sometimes car will not shut off at all 2005 Audi A6 4.2. It has been on service for same problem 20 times since April dealer states they can't do anything else. Audi of America basicly told me to f off. Anyone else have this problem
RE: Push button start
When was the last time you had it at the dealer
I know there is a bulliten for this problem that came out recently Also you may know it but the car wont start with the button if the key is in the ignition Have you noticed if the button feels different Have you spilled any type of liquid on it |
Yeah there was a recent post about a bad wire on the ignition switch that was shorting out. I am sure Audi has been looking at your ignition switch/ switches (push button). Tell them to run an ohm-meter or whatever those little electrical things are to find out why the thing is so crappy. Probably a wire.
wow, its a brand new car.........
ORIGINAL: dan908 Yeah there was a recent post about a bad wire on the ignition switch that was shorting out. I am sure Audi has been looking at your ignition switch/ switches (push button). Tell them to run an ohm-meter or whatever those little electrical things are to find out why the thing is so crappy. Probably a wire. Just a little more to it then a bad wire |
| All times are GMT -4. The time now is 08:29 AM. |
