RE:Hard start
Old Nov 25, 2011 | 11:56 AM
ed1404's Avatar
Question RE:Hard start
Hi Guys, last night after turkey dinner, i tried to start my car but wouldnt start, i tried again it started, but it started sputtering and i smelled gas like the car was flooded and the battery light came on for couple seconds and off .
has any one had this problem. i will appriciate your help. Thanks. Ed.
Old Nov 25, 2011 | 02:40 PM
02A6Beau's Avatar
maybe you ate too much and the car was just responding to the extra weight
j/k
sounds like your battery may be going bad. not enough cranking amps to the starter. when you finally got it started, the voltage drop would account for the battery light being on. Operation of the alternator got the voltage back up and the battery light went off. Take it somewhere that they can "load test" the battery. You definitely want a "load test" not just a "voltage test". That will let you know if the battery is putting out enough power to get the engine to turn over.
good luck
-not an expert, just an enthusiast
Old Nov 26, 2011 | 06:31 PM
ed1404's Avatar
Default RE: cold start
j/k
good luck
Thanks Beau, i think you are right about the battery, i have a load tester. i will check it and get back to you. Thanks again. Ed.
rccks96
Aug 29, 2023 08:58 PM
yknits18
Apr 15, 2011 09:14 AM
sa9023
Sep 2, 2010 06:31 PM
shane.trammell
Aug 13, 2009 01:07 AM
wings7351
Jun 6, 2007 09:52 PM
