rear foglights
is it true that the rear fog lights on my 01 a6 that only one side is suppose to work? i was reading this http://www.audiworld.com/tech/ext20.shtml
and it got me thinking. i was about to buy new bulbs cause only one side was working i belive the passenger side.
Yeah, only the one side lights up.. well at least on my 1999 A6, thats how it is. I actually remember reading somewhere in the manual, that said that only the passenger side lights up.. so you should be good!
You can ad a 2nd fog light if you want. All you need to do is open up the light cavity on the passenger side of the assembly (using a Dremel), tap a couple of wires.
Here are a few pics of what I am talking about. This is a pre-2002 assembly (smoked style) being installed on a 2002 car (that had the glossy black style), so I did not have to tap any wires.http://forums.audiworld.com/a6/msgs/599870.phtml
I hate to "change the subject" but I'm going to drop my 4.2 off at the shop for some work while I'm gone for Thanksgiving. What mods do you suggest that I have installed. I having a spoiler, springs (lowering) while I'm gone but since it's there....
ORIGINAL: dmrdennie
4K or less. I have new wheels that I'll install, more than likely, in the spring. I did look into an RS6 body kit that looked great but well out of my budget. The spoiler will be just over $250. The springs will be just over $550. I agree, there isn't much more that can be done.
Get the GIACECU chip - $6-800
Get theGIAC TCU chip to change shift points - $6 - 800
Milltek and Borla make a nice catback for the 4.2, but do what I did and save some dough. Buy Magnaflow Mufflers, cut out the center resonator, and replace the piping with 2.5 inch pipe. Get the same advantages and spend less dough. All of that will get you around 15HP...Not much but what the hell, it already has 300 horses. Vagcom the tranny to hold 1st gear in tip. I think it is pf32000..BD is this right? Thats about it for the motor unless you spend big $$ and if you are willing to do that you should buy a faster car out of the box...
Other MODS..Coilovers, sway bars, 18"rims, window tint, smoked tails by HELLA, nice 3" tips on exhaust (magnaflow), Bigger brakes (crossdrilled)....PIAA fogs...debadge the car..
