Rear Seat
Old Sep 29, 2008 | 08:59 AM
cudafish's Avatar
Default Rear Seat
2004 A6
Could someone tell me how to remove the rear seat bottom ?
Thanks
Old Sep 29, 2008 | 10:59 AM
TwinTurboC5's Avatar
Smile Rear Seat
Hi. These directions are for removing the rear seat bottom, which are taken from my Bentley Manual.
First (1st): It advises to disconnect the negative terminal from your battery (make sure that you have your radio security code before disconnecting power, or you will lose the ability to use the radio once power is reconnected).
Second (2nd): Lift up on the front and outside edges of the seat cushion...look for a small release tabs on the front bottom edge of the cushion. There should be three total in the front of each seat position at the lower edge just above the carpeting.
Caution/Warning:: Prior to step three, ensure that you discharge any static electricity by touching or grabbing the metal door striker or chasis.
Third (3rd): Once the seat cushion is loose, look for and disconnect the wiring connectors for both the rear side airbags and seat heaters if equipped.
Lastly, installation is the reverse of removal procedure.
Good Luck! It sounds straight foward enough. Let me know how it goes.
Old Sep 29, 2008 | 09:28 PM
a6hcw's Avatar
Be sure to wait several minutes after disconnecting the battery before you disconnecting any air bag, as specified in your Bentley manual.
Old Sep 30, 2008 | 02:31 AM
cudafish's Avatar
Thanks alot for this info. I really just need to lift the seat up a bit to reinstall my carpet after a clogged firewall drain clog. That will nerver happen to me again.
Thanks again
Alexei1987
Apr 2, 2015 11:11 AM
dasautoa6
Aug 18, 2009 04:31 AM
carcrzy24
Sep 11, 2008 07:18 PM
krieg23
Sep 4, 2007 09:34 PM
ugadawg24
Apr 4, 2007 06:01 PM
